Urgent Wrist pin question
750SX
DO IT
Palmyra
I got some wrist pin bearings with my hotrods crank for my 701. The wrist pin bearings and washers do not fit inbetween the hole in the piston on my pro-x pistons. Are the washers not needed with the pro-x pistons? I measured the bearings and they are 24mm. I have some kawi 750 bearings that are 25mm so I am thinking of using those instead. Does anyone have any input on this?
For the Kawi bearing you don't need the thrust washers.
For the stock Yamaha bearing (94-present) you do need them.
The 650 motors had wider bearings and did not need them.
So, if you're going to skip the thrust washers, use the Kawi bearings.
750SX
DO IT
Palmyra
that's what i was thinking matt, but wedo said with pro-x pistons, the washers are not needed. I cannot fit 24 millimeter bearings in the pro-x pistons with the washers. I'm just sticking the stock bearings in
oregon
Matt what are the benefits of using the washers? i have never used them or known anybody who has, and have never had a problem.
