What plugs to use with a pro-tec head?
What spark plugs should I use with a pro-tec non girdle head? I have been building my boat for a couple months and it is almost ready. I just have to go get plugs and some fuel and try to fire it,thanks
I don't know whether you need ES or HS plugs. Easiest way to tell would be to try either in the head and see how far the plug extends. You don't want it recessed in the head, and you don't want it sticking out.
Or, measure the depth of the threads and measure the plugs.
You can use Resistor or Non-Resistor plugs. Heatrange should probably be 8.
So, use B(R)8(ES)/(HS)
