home made internal fuel fill...
wydopen
onthepipe
I won't ride in the ocean by myself unless it's in the bay
me neither...the other day the surf was pumping (triple overhead) i didnt have my ski and my buddy was super amped so he charged it by himself..i watched but it was so sketchy..you couldnt see him when the sets would come in..he was dropping in WAY outside the pier and was riding within inches of the piliings...pretty sketchy..i was ready to jump in and rescu his pos ski if he lost it...i tired to talk him out of it but he wouldn't listen
oxnard111
Creative RE Purchasing
Chad the freakin animal.
teton
tetongravity.com
Washington DC
I have the perfect solution. it sounds crazy but it works. its what i did on my ski. however your going to need a stock SN fuel filler with cap.
I pulled the pickups from the top of my tank, then i carefully bent a 90 degree angle in each of the fuel pickups (the internal part) and installed the fuel pickup fitting where the stock filler used to be on the tank. installed a hose clamp and called it done.
then i took the SN filler put it in ice cold water, then put the top of the tank in some boiling water let them sit for about 5 mins and shoved the stock filler into top pickup hole in the tank. its a tight fit but once its in....its in.....seals perfect.
so my pickup lines run out of the back of the tank (hole near the waterbox) and are hidden from sight. and I have a perfectly functional filler on the top of my tank.
Its a really clean setup and best of all you dont need to cut/seal......none of that crap
if my words dont explain it....i can post pics later
teton
tetongravity.com
Washington DC
id be afraid of kinking the pickups...how far down to they reach with the bend?
just keep the bend smooth and give it a decent radius.....you'll be fine
mine reach just as far as they did in stock form......i lowered my stock line a bit (my reserve was too big)
teton
tetongravity.com
Washington DC
never realized how dirty my gas tank was.......
also there are some scratches on the filler (don"t mistake them for cracks)
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Ya, works good huh?:biggrin:
A bunch of us did that mod 3 years ago. Ventec came up with that. There is also some other set-ups too:
http://www.pwctoday.com/showthread.php?t=35302
