ADA head and OEM RN FA´s?
Mike W
Infidel
North Florida
If you install a reed spacer you will only have to do some minor modification to the flame arrestor. Just use a Dremmel and trim the area that will interfere with the center bolt.
Sospikey
Trying to get upside down
Sweden
Thanks for the pic!
So is this mod that you guys do or do you buy aftermarket F/As?
I understand that the OEM F/A is THE F/A to have once you start getting water in the bilge more frequently?
Mike W
Infidel
North Florida
Thanks for the pic!
Alot of people use aftermarket F/a's because they are running aftermarket carbs. Aftermarket carbs like Buckshots have the top of the carb cut off and a carb adapter installed. Then you have to run a a/m f/a.
Personally I like stock F'A's. They keep water injestion down to a minimum.
jura
X
Belgium
No mods over here with ADA and stock F/A's.
I only use the spacer plate.
I knew how much it costs. Just figured I'd throw it out there, for all to see. :bigok:
Crab
thanks darin...noswad!
Seattle
Sidestepping a bit, but what do you think these 44's and my superspacers would bring?
