Takes some grinding, but yes.
Thanks for the pic!
So is this mod that you guys do or do you buy aftermarket F/As?
I understand that the OEM F/A is THE F/A to have once you start getting water in the bilge more frequently?
Uh huh...and now let's hear how much that costs.
I knew how much it costs. Just figured I'd throw it out there, for all to see. :bigok:
No mods over here with ADA and stock F/A's.
I only use the spacer plate.
You must run 44's. You deffinately need to trim if your running 38's.
No, I'm running stock 38's and it works without shaving. The pic is my proove.
