- vallejo, ca
well it looks like i'm going to just defoam my ski so i don't know how much to get. Can anyone help? bare with me guys i am a newbie and this is my first sn build.
thanks
luis
thanks
luis
You need 4-5 cubic foot of foam.
The 5 cuft kit of 3lb foam that US Composites sells is perfect.
The difference between foaming with the 2lb and 3lb kit will be less than 5lbs.
ok, so one more question then...
2 lb foams saves 4.5 lbs of total weight - but structurally how would it hold up against a rider's weight and pounding on it? i mean 4.5lbs is 4.5lbs... LOL
Several people have run with 2lb foam without any issues.
Proper mixing is the key.
I've seen 3lb foam that was absolutely ********ty because it wasn't mixed right.
It will work fine like Matt said mixing is key.
Mark44
DO NOT USE ANY KIND OF HEAT GUN ON THE FOAM. Bad things happen FAST!
Mark44
LOL....I said microwave and warm, not heatgun and flame.:bigok:
