How do I Turf lighten stock chinpad
2006superjet
just one more part....
costa mesa ca
is the wdk chinpad a lot lighter than stock.
is there any reason to do this or should i just stick with getting the wdk chinpad for 155
if i can do it with oem what are the steps
W
wydopen
i guess this is as good a place to ask as any..im running an oem pad recovered with an ap designs cover...the foam is soaked..what can i use for foam to replace the stock foam and still use my ap designs cover and still have it fit right??..25mm HT underpadding??
thegoldenboy
RN Surgery... soon
Toronto
i did one not too long ago...
ripped off the cover, ditched the foam and just turfred right over the white plastic...
has held a few months now...
I did the same before Sausages took over the ski. I'm sure that pad will last for a while. Put some self tapping screws into the sides of the RN pole.
Frosty
New York Crew
Western New York
x2
i put two coats of contact cement on the plastic and three coats on the turf (letting dry in between). has not pealed at all.
Used the stocker plastic piece as a mold and fabbed one up out of fiberglass. Made it a bit smaller around the sides and back and then turfed it.......no more water logged foam pad!
