speedwerx pipe
on a sxi pro, i know the water goes in the manifold, but how does it go in the pipe. i was told that from the head it was going out the boat. so what do i do to get water in the pipe. do i put a T at the entrance, one goes to the manifold and the other to the pipe. and what about the heat sensor.
anyone can help.
W
wydopen
it goes from the manifold into the cyl..if its like most other pipes
yeah i inderstand that the water goes in the manifold then goes through the cylinder and out by the head. but like i said i was told that from the head it had to go out the boat. but now how do i get water in the pipe.
W
wydopen
i see..i dont know??..
should i put a dual cooling system. 1 line for the manifold, cylinder and head, and the second line for the pipe. is that any good. i don t really know jet ski s, what do you guys suggest.
I ran a team kawasaki speedwerx pipe on my SXIPRO superstock boats.
one into the manifold (exhaust) one into the rear of the cylinder (Tapped)
Three out of the head like any JSU or SPEEDWERX head. two front exits of the head over the side...rear exit from the head into the PIPE. then out
other would be to run one into the pipe from the pump - make sure the inlet size to the pipe is slightly smaller than the exit. Too much pipe pressure will collapse pipes.....
