Bilge pump switch????
Whtbread
More Brap Please
south jersey
What do you guys do for a switch? It looks like there are four choices. Switch on the handle bars, just the normal pull switch, water sensors and float switch. What works best for you?
Y
yamaslut
I use a lanyard switch similar to what the ski has... I can leave it on, or hook it up to my PFD in case I fall off it will switch on....
3wheelerdude
Talk less, Ride more!
Ontario Canada
I use a kill switch off of a 3wheeler (lol). I mounted it right in the center of the handle bars so it doesnt take any space closer to the grips. It getting crowded in there with the pull trim.
I've been using the JSS toggle switch for well over a year, in both fresh and salt water, without trouble.
sxi steve
Life's short, have fun.
Clinton Twp, MI
Bilge switch
I went to a local 'Murrays Discount Auto' and picked up a basic black plastic on/off switch for aprox $3.00. I have a Kaw 750 SXI-Pro, mounted it on the rearward-angled side of the plastic, 3 screw part, located under the handle pole, just forward of the handle bar pilot bracket. Totally out of the way and easy to flip when riding with your left hand. :cool2:
Slutty's setup is pretty cool. I believe he has a scupper so while the ski is moving there is no need for a bilge to be turned on. He has a lanyard attached to his vest, so if he lets go of his ski the bilge turns on. perfect IMO
Y
yamaslut
:biggthumpup:
i like slutty's setup...
DJ cant say enough good things about his.....but thats a freshwater application, salt use????
for just a switch you cant beat the blowsion rotary...its the only one that is potted in epoxy
bit
Rider Mod Needed
Catfish, NC
How long is a while? The connectors are definateley no good, but if the switch holds up in salt water for a year or so its probably worth a shot.
This will be my second full season in all fresh water. I ride ~60 hours a season. I don't use the connectors. Just cut them off, slide heat shrink on the wire, solder it together, and shrink it down. Everything is waterproof and vibration proof that way.
Y
yamaslut
mine is potted in epoxy as well...
SUPERJET-113
GASKETS FOR CHAMP BRAP!
The cheapest place I have found for the rotary switch is JSS (Jet Ski Solutions), everybody elso wants $40ish. The last one i bought from RIVA and it was $40, but it lasted me like 5 years.
I have one mounted under my handle pole.
motorhead10
98 superjet for sale
san diego, CA
well i forgot where i read it but somebody was putting 5200 on a toggle switch
i used this idea twice now
nomal toggle switch coated with 5200 on the back
rubber boot to seal the front
pretty simple and cheap
cost like 4 bucks
cost like 4 bucks
i did that when I put my fx-1 together about 3 mo's ago....it took a dump last weekend...
i used liquid electrical tape, a boot and a bunch of grease....
hot products also has the rotary switches (same one) for under 30 bucks :woot: i got a couple of them from duckman
brentR
way fast whitey
Toronto
stainless toggle switch mounted beside primer, i just kick it on and off with my foot while riding
