Whtbread
More Brap Please
- south jersey
What do you guys do for a switch? It looks like there are four choices. Switch on the handle bars, just the normal pull switch, water sensors and float switch. What works best for you?
Slutty's setup is pretty cool. I believe he has a scupper so while the ski is moving there is no need for a bilge to be turned on. He has a lanyard attached to his vest, so if he lets go of his ski the bilge turns on. perfect IMO
I have been running this switch on my 650SX for a while and it works great. I just bought another to put on my SJ because the switch on it crapped out.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMPR0&P=7
This will be my second full season in all fresh water. I ride ~60 hours a season. I don't use the connectors. Just cut them off, slide heat shrink on the wire, solder it together, and shrink it down. Everything is waterproof and vibration proof that way.How long is a while? The connectors are definateley no good, but if the switch holds up in salt water for a year or so its probably worth a shot.
i like slutty's setup...
DJ cant say enough good things about his.....but thats a freshwater application, salt use????
for just a switch you cant beat the blowsion rotary...its the only one that is potted in epoxy
well i forgot where i read it but somebody was putting 5200 on a toggle switch
i used this idea twice now
nomal toggle switch coated with 5200 on the back
rubber boot to seal the front
pretty simple and cheap
cost like 4 bucks
well i forgot where i read it but somebody was putting 5200 on a toggle switchi used this idea twice nownomal toggle switch coated with 5200 on the back rubber boot to seal the front pretty simple and cheapcost like 4 bucks
