Amsoil Injector, Dominator & Interceptor
ToddW
Web GuY
Folsom Lake - CA
So, the RedLine PWC oiL I used before was ASH-LES the HPI I use now is Low-Ash and the Dominator you guys are talking me into is HIGH ASH. (Or HIGH ASH LIKE)
I'm guessing more ash = more protection but like in my previous post more smoke... so
How can they have ASH-LESS and Heavy-Ash and they both protect near the same??
Does the ash-less use checmicals or what?
And what is YAMALUBE? is it Ash-Less or what ?
The reason I ask is that the previous owner only ran yamalube and the Red Line PWC oiL I ran sounds almost identica to YamaLube and after my first tank of Amsoil the ski doesn't start or idle near as good as it did on redline, now I have 2 tanks through and the same problem doesn't idle as good as it did with red line and doesn't start up the very first time like it did w/red line.
Hmmm... maybe I should go back to redline if it's similiar to YamaLube and what was run previousl!! HMMM
OIL IS CONFUSING!
Gainera2582
Power and Agility
Run the correct oil for your application. Using any api-tc oil, which is a low ash oil, will leave deposits in all non powervalved skis.
If you must run amsoil, run the hp injector. However, I feel pennzoil 100% synthetic burns much cleaner than that for less of a price!!!!
ToddW
Web GuY
Folsom Lake - CA
I have the HP Injector, and that's what I've ran the last couple tanks... also when I started noticing not idling as good or starting as easy as whenI ran the RedLine PWC oil.
