How-To split your hull
Boris
The Good Old Days
Grow a pair and hop to it
Trust me, when I get a RN hull that's exactly what I'll be doing.
Should make installing WaterDawg foot holds a breeze and I still have that dumb "sandblast the hull on the inside to make it thinner" idea.
With all the reinforcing everyone goes I'm sure all that SMC just isn't necessary. :biggthumpup:
2lick
Brap!!!
Limerick, PA
And they said it couldn't be done........
Awesome man!!!:Banane01: :Banane01: :Banane01:
Way to stick it to em:biggthumpup:
seriously thought thats a cool way of doing it..... i imagine we will more of this from others now.....
Thanks Moondance!!!
Thanks Moondance for taking my question seriously and answering it for me in PM. I appreciate it since the only way for me to learn more is to ask.
:biggthumpup:
Mouthfulloflake
ISJWTA member #2
NW Arkansas
thats cool.
IM too impatient and lazy though, id end up with my hull in about 35 pieces.
thats a GREAT way to get in there and really do some good reinforcing though.
( up under the nose, and the rear lower sides)
Yea you have access to everything. I did this to remove all the foam for an idea i have in mind. I also am going to shave the sides of the tray. Im going to mold my own footholds. Put footstraps. Shave the gas cap. Remold the nose a bit. Side exit exhaust. Reinforce everything. Paint my engine compartment. And maybe a few other things while im in there. I really have a good idea for a gear driven dual pump set up. I want to do it but i want to have this done by like mid may so i might hold off til next year.
Just alil add on. I scraped all the green glue off the top deck. FYI use a blow torch or a heat gun if your really patient to get it really good and hot. If you dont neat it up it will take the first layer of your fiberglass with it. I did it in a small spot at first took forever and was taking some glass with it. Broke out the acetylene torch and bam done. There must be 20+ lbs of glue between the halves.
