oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
To build or not to build?
I have some spare engine parts lying around. Debating on whether to build a 701 62T engine.
I have a 6M6 engine from a 93 superjet. I have torn it down to the short block. The engine looks so mint. Looks to be very low hours.
I also have a set of 62T cases that are pretty corroded, and the bottom half is pretty much done. The rod went right through the bottom on the front cylinder. The top half of the cases look great. One little little tiny mark from where the rod slapped the side, but other than that, just corroded.
Here is where your advice is need. I would be doing this engine build just the heck of it. I haven't rebuilt a yamaha engine before, and I don't really need an engine for any other ski. I would be doing it just to do it I guess.
Should I tear this 6M6 short block down, use the bottom half of the case and crank, get the top case bead blasted and repainted, and slap them together. I have a 61x cylinder that I need to re-sleeve, and stock 61x head lying around also. Any thing I am over looking when it comes to compatibility?
Recommendations? Comments? :smile: :Banane01:
