Super Jet Parts of WBII that fit SJ ?
Just got a waveblaster 2 and want to build a superjet or maybe another rickter. what parts will fit the SJ/Rickter ? i've heard things like rideplate is too big. start stop to short, etc. is the driveshaft too long? I've started a list, please add to it if you know for sure it'll fit.
Things that will direct transfer to SJ/Rickter directly from WB2-
  1. Motor
  2. Ebox
  3. -coupler cover
  4. -pump w retrofit(155mm)
  5. -coupler
  6. -siphon oem bilge
  7. -
  8. -
  9. -
  10. -
The superjet uses a 144mm pump and the wb2 used a 155mm pump. The big pump can be used but requires retrofitting. The drive shaft will not transfer over. I believe your couplers and midshaft housing will work but i am not positive about the midhsaft. You will need waterbox, exhaust, driveshaft, start/stop switch, pump stator, impeller, wear ring, nozzles, steering cable and i believe the throttle cable is a different length.
Remember, that engine has the 64x cylinder with has much higher port timing, the cylinder head is machined differently per cylinder which reduces the compression in one of the cylinders(I think it is the rear), and the stator and cdi run two different timing curves per cylinder
