needaride701
X-
- sj, cali
i want to get a low profile hood but i dont got the money. so im thinking of cutting down my stock 96 hood and glassing it! anyone got any thread or tips that would help me out or put me on the right foot?
I'd do it this way too. Scott from GA has a great looking hood he cut down.If you had an extra beat up stock hood I wouldn't be afraid to put the sawz all to it. I would get a lowered nose on it and draw the line you want it to follow. You will need to pull the hood liner out to work it on it from the inside. I like to use foam to shape stuff in for my first layer of glass. After you get a layer on the outside you can pull the foam out and add overlapping layers on the inside so it doesn't overlap the outer hood much. Get the shape really close with the foam so the fiberglass is as close as possible to the finished shape. This will keep the body filler to a minimum which is brittle and will crack if it is built up too much when it is abused freestyling.
But I like doing things the hard way...............
alright well ill have a think about this one for sure!! stay with stock, cut it down and mod it, or buy new?
