I have been having this problem intermittently the past 2 weeks. Here is a video of what it sounds like
The first time it happened I went to pull the plug wire and the terminal ripped out of the boot. I figured that was the problem. I ghetto spliced in a new boot end, taped it up, and I got an hours ride out of it before it started happening again. I thought I had just done a crappy job, so I dug out the wires from the coil and replaced the wires, gluing them in with 5 minute epoxy.
I had a hard time figuring out which wires to use and not use.
I used this wire to replace both wires
Now I have access to this wire
So I'm willing to dig out the yellow wire and try again.
I'm not sure if the wires I chose mattered...or if I just have a bad coil?
