- Home of the Steelers!
Doing some winter maintenance on my ski and noticed that the spline on my drive shaft was cooked. So, I pulled the mid-shaft unit to inspect it's spline. It was also cooked.
So I decided to do a complete rebuild of the mid-shaft unit and all has gone well up to this point. The C-clip pliers that I have keep flexing and aren't stiff enough to compress the C-clip. I even took an old pair of needle nose pliers and filed down the points to fit inside the C-clip holes, but they just keep slipping out under pressure.
So... how do you get this damn C-clip out?
