- Australia, Perth
Hey guys,
I finally found a Stand up jetski.
Basically found this kawasaki 550 js for $400 (cheapish in Australia). How can i know what year it is?
It had been sitting for a year after the owner had a motobike crash and now needs a hip replacement and can't do
anymore... I got there and it wouldn't turn over
the owner went to get his mate that had apparently rebuilt the motor with new machined head, machined crank, new bearings and bored to new bigger pistons with full gaskets costing about $1000+ about 1.5 to 2 years ago. So the 'mech' friend too the starter apart but nothing. We then took the engine off and turns out it was the pump/prop area that has sezied.
Hooked up the starter to a battery and did a compression test. Got 200psi in each cyl. I remember you said it should be about 130psi. Would this be because of the new pistons? Or is that way too much??
Ohh and it also needs the 'jets' in the carby. no idea what that is???
Anyway, what do you guys think? I bought it for $300.
Some pics.....
Already gave the engine compartment a clean. unfortunately no before pic but just picture about 10-20 years of oil, grease, sand and salt in there
The owner also talked about the stop button didn't work in the few last runs he had with the ski. I noticed this plug un-hooked. Followed the wire and it goes in the center arm. Would that be the cause??
Ohhh also the steering cable seemed to have seized too. Is there a way to un-seize it? or is it hard to replace?
Some pics.....
