- Shippensburg, PA
im wondering.... i have SINGLE cooling on a stock 701 61x/61x single carb blaster.
i have a milled stock head that was tapped for dual cooling. the head should be around 175-180 psi.
should i use this head now, or wait till winter when i tap my pump for dual cooling?
if i do use this head now with SINGLE cooling, should i "T" the 2 water outputs into 1, then run the one line to the headpipe?
opinions / suggestions wanted.
