Octane_114
LeT tHe gOOd tImEs RoLL
- Charleston S.C.
using that set-up... it's like riding on a rail. pretty freaking sweet. i cant say enough. only reason i was considering a magnum is i'm working on dropping a 1100 in another x2 hull.
Mag pumps are different. Where a 10/16 may work in a stock pump (or with a TBM/Afterburner) the same pitch prop is likely to not work the same on the Mag. Prop pitch, cutback and nozzle sizes have to be tuned just like jetting / Needles-Seat and Popoff in a carb.
i ordered SXR Thrust Force Pump Cone from blowsion on tues, since i blew my set back magnum pump up on monday at the lake. I've called skat trak many times and they said that me and one other guy blow magnum pumps more than anyone else. he says that i have to send it in every 6 months for rebuild or it gets VERY expensive.
-some of you Don't realize that 227 rides literally ( i'm not lying) 3-4 times PER WEEK in the salt. Skat Trak heard that i do that too and they said well of course your having trouble. thats like 150 hours on a pump every six mos. So 2 years of no maintaince (600 hours) on the pump, itll blow up everytime.
I'll let you know how the thrust force feels even though most of your won't care since you ride sj's.
what did that cost you?
compaired to a Mag, It wont be as good, but much better than stock.i ordered SXR Thrust Force Pump Cone from blowsion on tues, since i blew my set back magnum pump up on monday at the lake. I've called skat trak many times and they said that me and one other guy blow magnum pumps more than anyone else. he says that i have to send it in every 6 months for rebuild or it gets VERY expensive.
......some of you Don't realize that 227 rides literally ( i'm not lying) 3-4 times PER WEEK in the salt. Skat Trak heard that i do that too and they said well of course your having trouble. thats like 150 hours on a pump every six mos. So 2 years of no maintaince (600 hours) on the pump, itll blow up everytime.
ya, or an easier fix would be to not put 300 hours on your ski each year and sit on your butt.
oh and.. i just got the pump stuffer cone in the mail. i ll put it in and let you know how it goes. it better rock for 240 bucks!
i have ben running a mag pump in my superjet of around 8 or so years. 4 motors and 100 setup changes and still the same bearings. i would guess around 800 to 1000 hours on my pump. i run synthetic oil in mine. i now have mag pumps in all my boats blasters and all.
any updates with the install. did you like it. how dose it compare to r@d tbm or magnum
YEP, Just turn it up and dump in the fluid. Put cap / cone on and run her. If the cone has the removable bolt in it the use a fork seal suringe and fill it up even more (I did this on my OEM pumps as well. Never had a pump bearing issue. Replace them when I get a used pump and never again need to take the cone off. KNOCK ON WOOD. Intermediates are another storry GRRRRRRRRRRRRRRRRRRRRRRRRRR Freakn hate em.
