- Marshall, AR
So whats the plan for a bow eye bushing on the front after the new nose, how do the bob hulls come?
I think your going have to cut then in like I did.I was hoping to leave the bottom hull of the 750 complete for simplicity sake and strength. It would be nice to leave the motor mounts and pump one piece so there would be one less joint to potentially fail and less to have to measure and align.
You pulled a few aas fast as your build went.All nighter huh? More power to you.
Sea Doo one I'm thinking.So whats the plan for a bow eye bushing on the front after the new nose, how do the bob hulls come?
Does any one know if yamaha and kawi couplers use the same threads?
Any updates? How's it coming along?
Brian, pretty sure that green stuff is polyester. I've read that polyester doesn't stick to epoxy. The best bet is to just take some epoxy and add some filler to it to make fairing compound.
X2, I like uscomposites sm fairing compound additive. sands easy.
