Super Jet Rib grinding question...
Should I grind out all the ribs, or just the ones on the sides? I have already ground out the bottom ones and sanded the sides, just looking at the nose now. I saw a '95SJ build here and they ground out the side ones on the upper deck and left the ones on the top.
I think I know the answer but figured I would ask.
That's what I ended up doing. It's coming along pretty good between the grinder, die cutter, and rotary tool. Now to sand, I would kinda like to get one side laid up today.
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Yep, grind them all. Don't forget to reinforce your handlepole mounting area.
And the rib with the screw insert behind the battery box, grind that sucker out too... all it does is provide a pedestal for a zip tie holder.....
