- Cumming, Georgia
ADA girdled head with modified 33cc domes for a decked cylinder. Measured 155psi on a tired stock motor that was only 165 out of 185psi with 35cc domes. It had some slight pitting on the top that was filled with JB weld prior to bead blast and powder coat. It not been ran since powder coating with epoxy primer and wrinkle black. $150 shipped in US
62T trim nozzle bored to 85mm. Also freshly bead blasted, then powder coated with epoxy primer and wrinkle black. $70 shipped in US
Glass on sponsons, I was told they were made by CarterB. They also look very similar to the ones made by #ZERO. $160 shipped in US
ADA hood hooks. New, used for mock up then went a different route. $40 shipped in US
Blowsion finger throttle with Yamaha throttle cable adapter. $50 shipped in US
