- Lake Orion, Michigan
2 long nights and tons of mountain dew later, about 95% there... still need to actually start it up though! new handlebars will be here Monday.
finished installing the drive train i built for Daytona last night... nothing like waiting until the last minute. not as clean as i would have liked but function over form at this point (just needs to last 2 days of Daytona!).
-718CC 61x motor (82MM bore, new crank/pistons/sleeves/bore/hone)
-ADA girdled head, 31CC domes (shooting for ~200PSI or more)
-Mikuni 46MM carb
-Factory B Pipe (headpipe and manifold bored to 48MM)
-Riva CDI
-Stock pump/Skat prop
i had to use the resonator chamber from my powerfactor exhaust system because of the diameter of the pipe that goes through the hull and out the back... (made due with what i had to work with...) the stock long exhaust tube is not nearly big enough in diameter. right now i am not using the pisser on the chamber, just capped it off (i will route water here if it is to loud).
nothing crazy but should be a nice surf setup... or should i have just thrown the 1000CC in...
cya in Daytona!
-Mikuni 46MM carb
-Riva CDI
cya in Daytona!
