Yamaha 66e fans might like this
Heres a setup I'm going to test hopefully this week. Big bore 66e 950cc. This motor has Brandon Reeds custom cases, these allow the motor to set upright and also allow the 62t bedplates to be bolted on. I also have a prototype cast manifold from him that adapts the bpipe. Full size gas tank and superjet waterbox will be used too.
Safe to assume 62T msd t/l will NOT work with that setup?
62t ignitions will work with this setup, however for first test i'll run 66e tl. I'm also gonna run fixed powervalves for the test too because i dont want to grind up a nice headpipe yet unless i like the way it runs. I still need to do quite a bit of fitting, the manifold isnt exactly designed for a bpipe it was designed for brandons new pipe that is like a slightly larger bpipe. I've got to drill and tape the headbolt holes. Its quite a bit lighter setup than the stainless waterdawg adaptor plates and the pipe is much lighter than the drypipe. I'll be interested to see how this turns out.
