Waterdawg Prepreg Carbon f1-pro
RiverRat
Louisville, Ky
Unboxed it today!!! Not sure how long it will take for me to assemble but here we go. I need to plumb, assemble and clear the hull. Not sure if I am painting it or just doing clear and visual carbon. Unassembled weight is 40.6 lbs!! And it is very sterdy :purr:
RiverRat
Louisville, Ky
40lbs>??!!! o man ill take 2, is it based off a fx1>?
It is based on a fx hull but uses the superjet pump tunnel and pump. The nice thing about this hull is the superjet pump and drive shaft are direct bolt ons! No more custom built pumps to try and get the fx to plant the power :headbang:
Ohio
This forum will never ever get old with all these ridiculously bad arse hulls/builds constantly going down...my God man....awesome!!!! Just awesome!!
sjetrider
incredible, so what does this thing cost? edited to safe face, thanks for the enlightment Penguin, still a lil slow from the Mexican New Year!
RiverRat
Louisville, Ky
Epoxy resin. Cost??? You will have to ask Jeff about that. Depends on what you want. I am sure Jeff can chime in here and discuss specifics on the construction
