Scupper vs one way valve
SJBrit
Extraordinary Alien
Bradenton, FL
Depends on your riding: scupper drains more, but leaks more. My ski sometimes has to float in the water when I'm not riding it, so the scupper is a no go for me. If your ski is always moving while it's in the water then a scupper is the way to go.
Waste Land
Non Multa Sed Multum
Florence, AL
One Way
Pros - Doesnt leak much when sitting in water, cheaper
Cons - If broken, is a bitch to replace. Doesnt drain as fast
Scupper
Pros - Drains like crazy. Easy two min fix if broken, looks snazzy!
Cons - LEAKS! You can float for a bit if you have pumps on, but nothing very long
I personally went with scupper. I have a beach area that i stay at when not riding so it works out great for me.
Whtbread
More Brap Please
south jersey
I have a scupper and I also have to have my ski floating now and then because of my lift. I went to home depot and got a piece of pvc and a plug. When I have to leave it in the water I put the plug in and no leaks.
SJBrit
Extraordinary Alien
Bradenton, FL
Yup - I did the same with my one way, but I like the one way in case I forget. As Jesse says, I'm not looking forward to the day it breaks: it's a lot of work to replace it.
IceRocket1286
Metro Detroit
I wanted to do a one way, but dont need it to break on me.
I decided on a scupper, until i figured that I do leave my ski floating when we ride and take breaks, alot, and if I park at my buddies it just floats, and with a scupper it wouldnt float long
so I did neither, but I might do one or the other next winter.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
IceRocket1286 said:
so u have 2 one way valves and 2 scuppers?
yes and 2 bilge pumps. I got tired of my 24/7 scupper leaking in when you stop to rest or talk to someone. Also having to hit the bilge switch or holding the rubber scupper closed with my hand. It was the old style with no alum plate, but still Im sure it leaks it too. So i said fock it and put the home depot valves and bougth another scupper.
Waste Land
Florence, AL
Post pics? Thats boggling my mind...2 scuppers...2 one ways and 2 pumps...you plan on doing any submarine rescue missions? Russia is always in trouble these days.
SJBrit
Extraordinary Alien
Bradenton, FL
Matt_E said:
What would be the point of putting a scupper on a one way valve?
Not sure. It might help protect the one way from water impact when landing on the tail, but I pushed mine about 18 inches up inside the hull to stop that.
