My Paint Q & A with the Great One
Shonuff
I've got the glow
Memphis
I PMed Daylite on some painting help an here's what I got back.
Hey Mike,
First my disclaimer. I am a hobbyist who continues to learn by trial and error. There are certainly more experienced painters out there who have different opinions and undoubltably better practices than me.
That being said, I'll try and answer your questions below.
Q. I want to remove all of my old paint. Do I simply grab some 400 and go to work on it to remove it?
A. Removing ALL the old paint seems like a lot of extra work. I usually just do my best to make sure everything is sanded and scuffed up and smooth. But if you are intent on really removing everything, you might want to use a vibrating sander and a sanding block. Not seeing (and feeling) your hull it's hard to tell you what grit to use. you may want to use something a little grittier than 400 if you have some edges to smooth out, then go back with 400 to sand out the scratches. Just be careful with power tools, they can burn through a paint job and into the fiberglass pretty quick.
Q. Would this be a dry sand or wet?
A. It could be either. Wet sanding tends to make paper last longer because the water cleans out the paper and helps it from clogging things up. Try both and see what works for you.
Q. Can I use a small orbital sander or should I do it by hand with a sanding block or by hand with the sheet-in-hand only?
A. Real painters say to always use a sanding block because your fingers will run grooves into what ever you are sanding. And again, power tools are helpful, but can take too much off if you aren't careful.
Q. To wetsand with soapy (Dawn) water, do I put the mix in a sprayer and spray a section while I sand it or do I dunk the sandpaper in a small bowl of soapy water? How much water do I use?
A. I have a 5 gal bucket that I fill 3/4 full with a good squirt of dawn in it. You want to be able to put the sand paper in there to clean it off so a good amount of water in the bucket is a good idea. I'll use a sponge or green pad to get some extra water in areas that I want it or to wash off the "dust".
Q. You wipe it down with laquer thinner. How do you apply the thinner? Do I put the thinner in a sprayer and spray it on and wipe it off or simply dab some on a cloth?
A. I use the laquer thinner as my degreaser and final cleaning solution. I just get a paper towel wet and wipe everything down. Think of it like using a squeegy.
There are lint free cloths out there that can be used for this too. A wet paper towel has worked for me.
Q. The bottom of the hull has numerous scratches. Do I load up on coats of epoxy primer or go with a feather fill primer, fogging coat, and 320?
A. I have stopped painting the bottom of hulls because they'll get scratched again. It may be worth using a body filler on some of the deeper scratches. A filler primer would work well too. You could brush on a gelcoat too, gelcoats are pretty thick.
Q. What degreaser do you use?
A. laquer thinner works pretty nice. I am sure there are other things out there, but it works for me.
Q. How long do I let the base coat dry before I go to clearcoating?
A. Base coats should dry pretty fast, all depending on how fast the reducer flashes. They are a one part paint like rattle can paint so dry is dry, you don't need to wait for a chemical reaction to finish before painting over the top.
Q. Do I wetsand the basecoat prior to clearing? How many coats of base?
A. No, don't sand the basecoat. How many coats? enough to cover and show a solid color I suppose. I do illustration stuff, some of my "coats" are really thin to show transparency and such, so there is no real rule here. If your color is solid then you have enough coats. Work in light coats, don't try and color it all at once, this will let the earlier layers flash before another wet layer is applyed.
Q. I would like to put some Imron down , put the decals on , then clear. Can I put the decals on with the non-stick spray on my tacky paint or will that be bad for the base coat?
A. I have NEVER done it that way. I don't know if it would work or not. I would suggest clearing first then lay down your stickers then clear again.
Q. Can I clear over factory Yamaha decals?
A. I don't know why that would be a problem. I clear over stickers all the time.
Q. What respirator do I want? What sprayer do I want?
A. I have a turbine hvlp setup that came with a gun, it also has a forced air respirtator so I am not sure what kind of equipment to suggest.
Q. Can I build a booth in my garage with plastic and 2x4’s?
A. I don't see why not, it has been done before.
Q. I'm going to paint my engine bay, do I need to clear it as well?
A. Yes the fumes from the gas will lift the paint if it isn't sealed in the clearcoat.
I sincerely appreciate the assistance.
I hope that helps,
Daylite
Frosty
New York Crew
Western New York
That is an awesome write up... nice job. And thanks Shonuff and Daylite, This makes me feel much better about having just finished my first paint job. :Banane01:
Y
yamaslut
Guest
I would like to add a few things to his list and make some other recomendations...
  1. be very careful when using lacquer thinner. I would not recomend it as a pre-paint cleaner/degreaser. It dries way too fast and is difficult to work w/. I always use a designated "pre-paint cleaner" the solution doesn't evaporate as fast and the common method is wipe on w/ one towel, the immediately wipe off residue w/ another towel... "wipe on, wipre off"... Lacquer thinner will lift a lot of types of paint so be careful.. it will wipe the ink off the SJ graphics too..
  2. when sanding the old paint down for the first coat of primer, just use 180 grit in an orbital sander and for the hard to reach and edges, use a sanding block like daylite said. they make foam blocks that work great... they also make them w/ holes for better cutting with the paper. spray a good 2-3 heavy coats of filler primer, then the trick of "guide coating" comes in... You will need a can of flat black paint and once the primer is dry lightly mist the ski w/ the flat balck paint. when you are done it will look like someone lightly dusted the ski w/ black paint (duh)... this gives you a way to see the depth of the scratches while sanding... so for example, get a wet sanding block and some 400 grit paper and start sanding an area, notice the black lines in the primer, those are the scratces showing up... now all you have to do is sand till the black is gone... if you sand back through the primer and ther still is a scratch, spray it w/ more primer, or fill it w/ polyester filler using a razor blade and the spatula, then repeat the earlier steps again... werd??
  3. once the ski is prepped and ready to paint, always, I mean always use a SEALER!!! it is very inportant that you seal out the primer ans sand scratches, if you don't the scratches will suck up the paint and make it die back... the purous surface from all the open scratches from the sandpaper will suck the paint right up, and kill the gloss... Sealer does what it says, it saels the scratches and cuts from the sandpaper giving the paint a solid non-pourous substrate to adhear to... never sand a seal either (obviously) or it is useless. And all saelers are wet on wet applications
  4. 3m makes throw away reperators fro around 20$, they last 45days of use...
  5. I used an epoxy based appliance paint (rattle can) that holds up to fuel and all the other crap in my hull... Lowes stocks it and I belive it's made by American Tradition
  6. never never never sand a basecoat w/o re-appling a new coat of color before clear
  7. I don't use soap when I wetsand, just plain water for me, less buildup and less to clean off when you are done.... Not saying my way is right, just giving another option...
