ski_crazy
ISJWTA member #5
- Holts Summit, MO
This is the tear down and rebuild of my project SXI. If you got any questions or opinions feel free to post up. What it looked like when I brought her home.
This is the begining of the tear down. I did the bars and hardware last weekend getting it ready for the new UMI set up. Also removed the mats and tray trim to get it ready for the Water Dawg foot holds and removal of the rear container tubes. The back end will be completely shaved, exhaust too.
This is the new battery mount location. This is just a mock up for now. But by moving this battery forward I add a little more weight to the front to help off set the fact that I am 6'6" 250lbs. This also makes room for the new front side exhaust hose routing and fire extinguisher mount location.
The motor was pulled tonight. And I found I need a new motor mount. Anybody got one laying around?
I am also going to remove the front gas filler location and put the filler directly on the tank inside the hull, about where the fuel filters are resting. I have gotten all new bright toxic green fuel line. The dash will be shaved also and primer moved under the hood. I haven't picked a color or graphics out yet.
