2006 Rn
Mike W
Infidel
North Florida
2006 Rn**SOLD**
ENGINE:
62T/61X stock porting
-Single 48mm Novi
-ATP Single manifold
-Stock F/A (X Metal riser)
-Stock reed cages with Carbon Tec reeds
-Lightened flywheel (LPW)
-Factory B Mod pipe(Team Scream Modified)
-Stock waterbox
-ADA girdle head w/ 35cc domes
-Jetworks flow control valve
-JSS Bulb Primer kit
ELECTRONICS:
-Stock w/ MSD Enhancer
PUMP:
-Skat Trak 12/17
-Wet Wolf pump cone
-Dual cooling
HULL:
-Reinforced hull/ bondline/pole bracket area
-X metal scupper
-Rickter footholds
-Black diamond turf
-Single Rule 500gph bilge w/ bracket
-Military grade bilge switch w/ handlebar mount
-Hood straps
-Worx rideplate
-Worx 201
-Wamilton hood hooks
-Hydroturf chinpad cover
STEERING:
-UMI billet pole bracket
-Riva pole spring
-Stock pole -2 1/2"
-UMI Steering
-Blowsion -1 turnplate
-Limiting rope
-UMI finger throttle
-0* UMI bars
-ODI Ruffian grips
