onesojourner
I use a thumb throttle.
- springfield, mo
specs for now are
2000 sj
riva ride plate
riva intake grate
stainless prop of unknown pitch
k&n flame arresters (not that thats a good thing. any one have the stockers they want to get rid of?)
well I brought home my new ski and I am going to cut some holes in it. I am putting a pair of R.E.V.s in for now. I also am waiting on the for the 5200 to cure and keep the attwood bilge in place. I don't really have any huge plans beyond that but I am sure that will change when I get some ride time on it. right now I am thinking of some sort of quick steer set up, but enough of the day dreaming. so far I have the turf all ripped up and the adhesive stripped. I did realize that there is a huge difference in 7 year old turf and 16 year old turf. my friends SJ was a nightmare to get the turf up, mine I could peel up with my hands almost in one whole piece. here are some pics of what I have done.
I used a heat gun to take the rubber moldings off then I heated up a scraper to sort of slice through the rest of the thick glue they left behind.
I found a slight cracked in the tray but the foot holds will take care of that I also found an air bubble under the paint under the rubber molding so I will have to fill that in.
the goof off worked alright but if I were to do it again I would look for something a bit stronger.
I got it all cleaned up finally. took me a couple of sessions but its finally done.
now I have to prep for the glass work. the goof off left an oily residue. What should I use to clean the tray for the glass work? also do I need to rough the tray up for the turf? I want it to stick but I also want to be able to get it up in a few years if I need to.
2000 sj
riva ride plate
riva intake grate
