Checking to see what the interest level is on this rear exhaust kit. Made by 701 Industries I will be importing these kits which will come complete with exhaust tube/outlet, block off plate, and hardware. Initial pricing will be roughly $119 (possibly lower) plus actual shipping.
Trying to figure out how many to order, this will affect pricing as shipping from Australia is expensive...............please shoot me a PM if you're interested in anything so I can determine my order amount.
rear exhaust kit
Will also be bringing over dual urethane motor mounts, surf proven by Aussie riders. Soon to be backflip tested by one of our board members.
701 Industries: my mission statement to engine mount manufacturer was to build a mount that will dampen engine vibration, will soak up any impact and not break and thirdly be affordable.So a conventional style mount uses a billet or cast alloy base, then on top of that is glued a rubber or urethane dampener and than on top of that is glued basically a threaded washer. then its up to the strength of the glue to hold it all together . Heres the cool part about 701 mounts. NO GLUE. They are a full dual urethane mount with a full billet alloy core. In the manufacturing process the base and the stock are poured into the mould with the alloy core in place to form a one piece mount. Its a special process they use to make the base harder than the damping stock but what you end up with is a virtually indestructible engine mount that controls all the motor vibration from the top to the very bottom of the mount. Traditionally you would tighten your mount down hard , all that is required on these mounts is 10 to 15 lbs of pressure. Remember the whole of this mount is being used for dampening.
dual hood shock kits
more unique parts to follow like motor mount keepers, recessed rear hand holds, stainless freeride steering..............please shoot me a PM if you're interested in anything so I can determine my order amount.
THANKS
Chris
rear exhaust kit
THANKS
Chris
