| Driveline Engine, ignition, jet pump, everything that makes you move |
Thread Tools | Display Modes |
#1 |
I've got the glow
Let's Leafblower Turbo Something
Let's stick some crazy big jets on a superjet with a drypipe and leafblower-turbo it.
Is that genius I smell? |
#2 | |
X-H2O
Quote:
And stick the leafblower where? Gonna wear one of those backpack leaf blowers?
__________________
96 RN Superjet- Protec, MSD and all the other goodies 97 RN Superjet- Project - Parting out |
#3 |
Dallas/Fort worth
my opinion of genius would be the guy who could use a wind powered turbine to centrifugally extract oil from an algae pond, thus harnessing solar/wind power to create fuel... but leaf blowers are cool too.
sorry for the rant, I just filled up the skis,ram,boat,bike,mustang,weed eater,lawnmower,lantern,rc car and now need a home equity loan to sustain that trend. |
#4 |
X-H2
I have always wondered if a leaf-blower could work as a turbo/supercharger. I have no Idea how many PSI a leaf blower can create or if it has enough CFM for a decently thirsty engine, but it would be fun to find out.
#5 | |
RIP SFL 1/16/06-2/04/2010
Location: Out saving endangered species of Kawasaki standups
Quote:
So would you tie the throttle into the throttle of what you were supercharging so that the two spun up at the same rate?
__________________
I'm not one to go around spreading rumors, no really I'm just not the gossipy kind, You will never hear of me repeating gossip so you better be sure and listen close the first time.
#6 |
ISJWTA member #2
It wont work.
more electrical energy would be required to actually STUFF any forced charge than the engine would gain from that "stuffed" charge. you cant get something for nothing when it comes to energy.
__________________
hand me the piano.... |
#7 | |
Quote:
__________________
#8 |
i wear a suit to the bank
Go green, use electric!!!
__________________
My squarenose conversion, 267lbs ready to ride
"I wish I could be evil. Let's be an evil spider family." |
#9 |
I thought we would use a two stroke to supercharge a two stroke!
__________________
#10 |
Your Momma's Lover
I already went green. I ride a Kawi. LOL!
__________________
2009 Dodge Challenger RT - TorRed, 375HP, 6 Sp stick, and rolling on 20's. 2008 F250 4x4 Diesel King Ranch |
#11 |
PIN IT TO WIN IT
#12 | |
X-H2
Quote:
But I digress, your interpretation of the law is very flawed. By your interpretation superchargers in general would not work, as they would take more mechanical force to produce a chanrge than the charge would improve compustion. As we all know superchargers do in-fact work every day. As for an electric one working, that would come down to the jet skis charging system efficiency and the efficiency of the leaf blower. I think the OP was talking about a 2 stroke Leaf blower though. |
#13 |
down with the sickness
I tried that on my 400ex quad a few years ago and it didn't turn out too well due to no bypass and since it had a carb I guess you have to equalize the bowl pressure with incoming pressure to work
__________________
95-750sx 96-wr 88-650sx Gelcoat's great if you remember to add hardener! |
#14 |
Speak up ,don't kiss azz
__________________
Originally Posted by SuperJETT Dear hangtime,You have received an infraction at X-H2O - Epicenter of Freestyle and Freeride jetskiing. Reason: Insulted Other Member(s)--------------This infraction is worth 1 point(s) and may result in restricted access until it expires. Serious infractions will never expire. |
#15 | |
formerly known as jfw432
Quote:
WTF lol
__________________
My SN build: http://www.x-h2o.com/showthread.php?t=46771 Can't wait until I get mine! www.highroller-customs.com/stunt/ |
#16 |
nawwwwwwwwwwwzzzzzzzzzzzzzzzz!!!!!!!!!
__________________
#17 |
変更されるエンジンの建築家
Most 12 Volt blowers on put out 150 CFM or less and that's far less than your engine needs to run in the stock configuration.
These electric blowers work great for moving air but are NOT designed for the volume and pressure required to supercharge an engine. Real superchargers flow 600 CFM or higher and are designed to do it at 5-15 lbs boost pressure. Also sticking some crazy big jets with an electric blower motor would make your jet-ski perform worse than stock.
__________________
. Life without danger is a waste of oxygen, so go buy a SuperJet and start breathing water. |
#18 | |
Quote:
Ok heres my idea lets seal the compartment completely and put positive pressure in it with pure oxygen,or an oxygen mixture,either it will run like a bat straight out of hell or blow all to hell because of an errant spark somewhere.
__________________
#19 | |
ISJWTA member #2
By my post above, I meatn electrical superchargers wouldnt work.
you would need a generator the size of a VW bug to make enough energy to electrically actually over come atmospheric pressure on a 701 engine intake. superchargers... yeah, they bolt on the engine, and use the engines power to spin them, ever seen the belt on a 6/71 blower? I figure its rated for 80HP or so ( the belt) im sure in the upper RPMS there is an advantage with the supercharger, but Id bet it taxes the bejeesus out of the engine all of the rest of the time. dragsters use them, in a VERY precise and narrow focused use. regardless, yeah im no physcisit, but I can tell you there is more to it then strapping a leafblower to the intake. hell why not ad some of those "hydrogen generators" to the setup too? and then run some slick50, and octane booster. \might be able to get 400 HP out of a 701. Quote:
__________________
#20 |
Pure oxygen? Definately EXPLODE
__________________
| Thread Tools | |
| Display Modes | |
