Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1
    PIN IT TO WIN IT DAG's Avatar
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    DAG's 2010 Black Betty Build
    Start Off with Some Inspiration
    Figured I should start a log so I won't back out of the much needed recondition.
    Plans:
    • New Turf (color undecided)
    • Paint (appliance epoxy black)
    • Cheap vinyl (need to design)
    • Carbon/Glass reinforcement
    • Fix OEM foam holes
    • Check foam wetness
    • Center mount 5lb battery
    • Figure a way to mount an extinguisher.
    • B-Mod pipe is getting chomped up knocking off the motor mounts (looking for a solution be for a hole gets knocked into it)
    • re-wire using heat shrink and weatherpack connectors
    • Turf with thick underpad
    • Relocation bilge
    Maybes:
    • Wide tray mod
    • Oneway valve
    • -2 Hull
    • D Cut plate
    • glass over OEM filler
    • Bilge switch on pole
    Goodies:
    • XMW box
    • Lighter hood
    • Trinity Footholds
    • 5lb battery
    Pretty basic stuff, just need to get it done.
  2. #2
    CFL Cheapass. Foximus's Avatar
    Join Date
    Sep 2007
    Ovie-ado
    Posts
    1,945
    Thanks
    0
    I have/had the same problem with my chamber. Just sand the area and dap on some turf in a pretty pattern.
    Fox the Pirate
    Sailing : 1989 The sj550 mkII 701&140mm pump
    Warning: The above post contains pessimism and player hating to the highest degree.
  3. #3
    Formerly Motoman25 BruceSki's Avatar
    Join Date
    Nov 2007
    Long Island
    Posts
    6,219
    Thanks
    263
    or smash it with a dead blow hammer. the dents won't negatively affect performance
    I rockered my sneakers so I don't pearl walking down the steps!!
  4. #4
    LKN Freestyle Militia CoreyLKN's Avatar
    Join Date
    Jun 2006
    Lake norman, nc
    Posts
    1,837
    Thanks
    0
    Get it done!!! We got riding to do this summer
    -Optima Racing-
    Check it out at Optimaracing.com
  5. #5
    I'm on a boat
    Join Date
    Dec 2009
    Danville, CA
    Posts
    52
    Thanks
    1
    I put a couple of pieces of turf under my waterbox. That raised it up enough to where the stinger cleared.
    Breaking parts at a drag strip near you.
    487 RWHP 2003 Ford Mustang Cobra
    Pro mod 69 Camaro 6.01 @ 242.16
  6. #6
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    As a progress update in the last few weeks I've pulled the engine broke down inspected, sent cylinder out for a fresh honed and reassembled with new rings. Removed turf on the rails and spend many hours sanding gel coat. Started grinding the ribs and drilled a small hole in the back to see if any water would drain... I wanted to break it all down to understand what i was working with. Turns out its going to take a bit more than expected.
    Good news: XMW box came in and got Ratti's old 24/7 hood.
    Pic's so far.
    As I begin
    Sanding Progress
    Ribs and Glue
    Pic's of the B-Mod which is knocking off the motor mounts, going to add some extra padding under the box to raise it up a bit.
    Next Steps
    • Weigh bare hull
    • Order glassing supply's
    • Order footholds
    • Order turf and underpad
    • Research weatherpack connectors
    • Remove current holds in one piece
    • Remove turf in tray and sand
    • Finish Grinding ribs and prep for glassing
  7. #7
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    For flatwater, is one layer of 8oz carbon enough?
  8. #8
    Join Date
    Sep 2007
    Ovie-ado
    Posts
    1,945
    Thanks
    0
    For where? Reinforcing the engine bay?
    1 layer of 8 wont do nothin.
    Fox the Pirate
  9. #9
    Join Date
    Nov 2007
    Long Island
    Posts
    6,219
    Thanks
    263
    Quote Originally Posted by DAG View Post
    If you haven't broken it yet doing flatwater what makes you think its going to break now?
  10. #10
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    Quote Originally Posted by Motoman25 View Post
    started rolls at the end of last season and hitting kinda hard
    8oz of glass and 8oz of carbon? I really want to keep this thing light since i only ride lakes.
  11. #11
    Join Date
    Sep 2007
    Ovie-ado
    Posts
    1,945
    Thanks
    0
    Just add one layer of 17oz biax. wet it out, slap it on, and then spend the next 10 minutes squeegieing out every last bit of resin. Your talking a few ounces difference between two layers of 8 oz... but the relative ease of using 1 layer of 17oz and eliminating the chance of fudging up and geting airbubbles all over just makes it worth it.
    Fox the Pirate
  12. #12
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    17oz Carbon is alot more than 8oz of Carbon.
  13. #13
    Join Date
    Sep 2007
    Ovie-ado
    Posts
    1,945
    Thanks
    0
    not when your doing 2 layers of 8oz. The wieght is in the resin, not the cloth.
    Fox the Pirate
  14. #14
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    good point
  15. #15
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    Weighted the bare hull with mid-shaft
    hull sitting 115 Looks like i don't need to dig the foam out after all!!!
    Now i need to get together a BOM for supply's
  16. #16
    X-H2O.com ncbrock's Avatar
    Join Date
    Apr 2009
    Raleigh NC\Lake Jordan
    Posts
    1,556
    Thanks
    1
    well since you were planning on refoaming, you should refoam my ski
    Im grinding down my ribs today, and I and the whole ski were covered with fiberglass dust, really messy.
  17. #17
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    I found out today that learning rolls is going to cost alot of money, composites are not cheap...
    Also Ordered a set of Trinity Holds
  18. #18
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    Composites on the way time to prep for the layup. Sand Sand Sand
    Dug a hole for the oneway Confirmed DRYFOAM!!!
    115 dry weight (before foam removal and w/ midshaft in)
    FootHolds anyone?
    Next Steps
    • Order weatherpack connectors
    • Install Oneway
  19. #19
    Join Date
    Sep 2007
    Ovie-ado
    Posts
    1,945
    Thanks
    0
    :-):-):-):-) man, that sucks. you just jynxed yourself. Now its surely to become waterlogged in the first 20 rides.
    Also, heres some advice on the weather packs... I just did them all over my ski. BUY THE CRIMP GUN. I did not... and i have been having nightmares ever since. the wires slide out of their leads even if you follow his "non crimp gun" instructions. I just said screw it and took them all apart and soldered every lead onto its wire.
    Fox the Pirate
  20. #20
    Join Date
    Apr 2006
    Lake Norman, NC
    Posts
    4,903
    Thanks
    140
    If that's the case I'm just going to heat shrink the little shiits the guns are quite expensive...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
