Page 1 of 8 123 ... LastLast
Results 1 to 20 of 159
  1. #1
    X-H jeastes1's Avatar
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    The why would you build a sn?
    So I picked up this old square hull a few months ago, also grabbed up vxr pro for a donor. I was gonna just put it together to replace the fx that i had sold because i didnt have the time or money to put into it. Making quit a few changes, not sure how it will ride, but after riding a xfs I knew I wanted a shorter, rockerd hull. Im on a budget and I have pretty dialed in rn that I love to ride as well, so I hope this will tie me over till I can get a AM hull.Click image for larger version.
ID:	169872Click image for larger version.
ID:	169873Click image for larger version.
ID:	169874Click image for larger version.
ID:	169871Click image for larger version.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	169890   Click image for larger version.
ID:	169891   Click image for larger version.
ID:	169881   Click image for larger version.
ID:	169882   Click image for larger version.
  2. #2
    WHERE-THE-SEAT-AT 5810's Avatar
    Join Date
    Sep 2006
    Knoxville TN
    Posts
    1,134
    Thanks
    112
    cool, get rid of the 2 part foam. it will water log. i went styrofoam and will never go back
  3. #3
    F-N9NE Factory928's Avatar
    Join Date
    Apr 2011
    Bullhead City AZ
    Posts
    377
    Thanks
    59
    sweet...another thread making me want to keep my square lol
  4. #4
    X-H Iland Trader's Avatar
    Join Date
    Sep 2008
    Boynton Beach, FL
    Posts
    201
    Thanks
    3
    Mucho trabajo- good luck
    in THRUST i trust______________________________________
    Every neighborhoods got one- in mine, I'm him
  5. #5
    Tahitian rider loictahiti's Avatar
    Join Date
    Sep 2006
    Tahiti, french polynesia
    Posts
    734
    Thanks
    1
    waouuuu you rock
    i subscribed right now
    keep us informed
    VXR 3 Y flat deck stroker+ 6 with SJ handlepole
    SJX2 fixed steering 760
    http://www.youtube.com/watch?v=AmYpM...07C08E440F7383
    LOL hull 300sx based + SJ pump, in progress....
  6. #6
    X-H2O.com sportfish258's Avatar
    Join Date
    Mar 2008
    Posts
    1,531
    Thanks
    29
    Nice ..... I see you are using my patented rocker technique. It's a pretty good method IMO. Let's you keep the SMC as structure to bond to. Pm me if you have a question . I learned a few things doing mine.
    Many thanks to Jet works and Black jack performance for making a midlife crisis tolerable .
  7. #7
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    Thanks for the comments,Sportfish I may have looked at your build a few times before doing mine, actually maybe a few hendred. surprised no one commented on the rockered rear, anyways I took off four inches on the bottom rear and rockered it 3/4 of an inch. Added drains home depot one way, lowered, larger , exhaust tube, gonna be wider tray with toby footholds, also lowered and straght out off the back. I shortend the front, not sure how much rocker but i started it just in front of the front motor mounts, and i can just fit a stock gas tank in, I hope? Click image for larger version.
ID:	169928Click image for larger version.
ID:	169929Click image for larger version.
ID:	169930Click image for larger version.
  8. #8
    X-H2O.com MCrider's Avatar
    Join Date
    Oct 2009
    Jackson MI
    Posts
    1,098
    Thanks
    78
    Nice your from jackson! Im digging how your doing your tray i may have to wait to finish mine to see how you finish yours!
  9. #9
    X-H
    Join Date
    Aug 2011
    syracuse
    Posts
    141
    Thanks
    1
    How did you make another bond rail?
  10. #10
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    As far as the tray im still in the air on how il do it, planned on wider with standard holds but not sure, I ground alot of material off the top on the rails as to make room for three layers of 12oz biax cloth, and same on the bottom, lots of grinding! Sn top decks are made with some weird material looks like saw dust when you grind it
  11. #11
    X-H2 EvanKrefski's Avatar
    Join Date
    Oct 2011
    lake orion MI
    Posts
    260
    Thanks
    6
    That would be sweet if you made a mold of that hood.
  12. #12
    Do Good Crew!!!!!! 'kotajoe's Avatar
    Join Date
    Aug 2010
    NRH, TX
    Posts
    538
    Thanks
    22
    Gotta love a good square nose build, keep the pics coming sir
  13. #13
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    More progress
    Heres a few more pics.Click image for larger version.
ID:	171296Click image for larger version.
ID:	171295Click image for larger version.
ID:	171298Click image for larger version.
  14. #14
    formerly superjet444 Tmart's Avatar
    Join Date
    Jul 2011
    Middle Georgia
    Posts
    692
    Thanks
    25
    Impressive build. That tray is wide as hell
  15. #15
    Join Date
    Oct 2009
    Jackson MI
    Posts
    1,098
    Thanks
    78
    In all honesty would you consider helping me do my tray?
  16. #16
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    Quote Originally Posted by MCrider View Post
    I would consider it, but honestly I would not have time until this thing is all done.
  17. #17
    Join Date
    Oct 2009
    Jackson MI
    Posts
    1,098
    Thanks
    78
    ok, for the tray did you just lay out glass and make that piece flat then cut to fit?
  18. #18
    Join Date
    Apr 2011
    Bullhead City AZ
    Posts
    377
    Thanks
    59
    thats a FaTlIp, looks like that hood aint going no where..nice progress
  19. #19
    Join Date
    Jan 2011
    clark lake, MI
    Posts
    196
    Thanks
    1
    Yep you could use a piece off glass, i used a piece of drywall covered with plastic, just what I hadhad laying around, just measured it out around the pump and made it a lil bigger for trimming, but I also cut the upword angle out on the back of the pump opening, I used plexy glass in different thickness as a mold for filling that back in with glass, did the same on the pole mount area, used 1708 biax cloth, four layers. It takes forever just because you need every surface flat to build up the glass, so you can usually only layup one area at a time then wait for it to harden, I found that using chopped mat on corners helps where the thick cloth wont lay right, Thanks for the positive comments, its turned into alot bigger project than I had anticipated, but thats how it goes.
  20. #20
    Formerly JJC568 N3vrSat1sfied's Avatar
    Join Date
    Jul 2008
    Plymouth, MI
    Posts
    2,384
    Thanks
    91
    subscribed
    2013 Q8 Sky build: 781 Jetmaniac BB, 145 Skat Mag pump
    "If you lose your cool, You might not ever find it!"
    Torch Lake Freeride
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
