Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 154
  1. #101
    Customizing addict Waternut's Avatar
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Footholds are like the 615's I had but wider and a little taller.
    My custom made hull: http://www.x-h2o.com/showthread.php?...eral-quot-hull
    You can call a hull yours when you've modified it enough to be happy with all aspects of it.
  2. #102
    formerly superjet444 Tmart's Avatar
    Join Date
    Jul 2011
    Middle Georgia
    Posts
    692
    Thanks
    25
    Incredible work. Enough said
  3. #103
    X-H2O.com sportfish258's Avatar
    Join Date
    Mar 2008
    Posts
    1,530
    Thanks
    29
    Look at you mister fancy toothy exhaust man ..... Nice work 50 pounds .... this thing is going to be a feather .
    Many thanks to Jet works and Black jack performance for making a midlife crisis tolerable .
  4. #104
    I pretty much love beer chad's Avatar
    Join Date
    May 2006
    Cheney lake Kansas
    Posts
    2,039
    Thanks
    70
    LOl,, Sport .,..thats a suppperrr scarrryyyy exhaust
    Currently building RCW Brawler..EME 1K build on the way
  5. #105
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    I guess these are long overdue. I just haven't really felt like posting any updates lately.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	180017   Click image for larger version.
ID:	180016   Click image for larger version.
ID:	180015   Click image for larger version.
ID:	180014   Click image for larger version.
  6. #106
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Some more...
ID:	180025   Click image for larger version.
ID:	180024   Click image for larger version.
ID:	180023   Click image for larger version.
ID:	180022   Click image for larger version.
ID:	180020   Click image for larger version.
ID:	180019   Click image for larger version.
  7. #107
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    and now waiting for paint to dry...
    Oh almost forgot. I weighed it just prior to priming it and it was exactly 50 lbs. That includes all fittings, mounts, etc. The only exceptions are the D ring that goes on the nose, pissers, and bilge fitting because I didn't want to have to mask them off.
ID:	180031   Click image for larger version.
ID:	180030   Click image for larger version.
ID:	180028   Click image for larger version.
  8. #108
    What? Sanoman's Avatar
    Join Date
    Jun 2009
    NE Tenn
    Posts
    2,875
    Thanks
    186
    Nice work Nut!!
    And how much more blue have you got??? lol That gal should be about used up.
  9. #109
    salty nuts WAB's Avatar
    Join Date
    Jan 2006
    coastal GA
    Posts
    2,403
    Thanks
    38
    WOW! I just watched the timelapse layup vid. that was really cool
    great job on the hull!
  10. #110
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Top deck painted...
ID:	180314   Click image for larger version.
ID:	180312   Click image for larger version.
ID:	180315   Click image for larger version.
  11. #111
    X-H2O.com Brian_216's Avatar
    Join Date
    Jun 2007
    Harveys Lake PA
    Posts
    1,356
    Thanks
    70
    updates?
    ragecompositeworks@yahoo.com
    - Im not in it for the money, I just wanna ride!
  12. #112
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Well I went waterskiing, wakeboarding, installed fat sacks in my ski boat, mountain biking, some more waterskiing........oh you meant the jetski....LOL. It's padded, scuffed, and ready for turf. The pump, engine, and midshaft are installed. Pole is installed. Electrics are installed in the hull but aren't hooked up yet. Hood isn't 100% finished but it's as finished as it's going to be for the first few rides. I just have to add breather tubes or splash shields inside but it'll be fine for a little while. I've been slacking pretty bad lately but it's getting there.
  13. #113
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    So it was windy, cold, and choppy on the lake today so no waterskiing. That meant there was time to actually work on the ski for a change. Getting there...
ID:	181397   Click image for larger version.
ID:	181396   Click image for larger version.
  14. #114
    Join Date
    Jun 2009
    NE Tenn
    Posts
    2,875
    Thanks
    186
    l should have stayed at the house and worked too.Hornedogg and l decided to go out about 3pm yesterday.Windy and cold! lt was 55 degrees when we got out it was 48.The water felt good but the wind made it too cold.
    The freak did well and John got Idok's f1pro together and running.Light little 2x4 she is! Strong motor and once dialed in,the f1 will be bad azz!
  15. #115
    Saving the day. McDog's Avatar
    Join Date
    Jan 2007
    Georgia
    Posts
    5,683
    Thanks
    198
    Look like turf is all you have left. Maiden voyage this weekend?
    "Too bad you can't buy balls." - Brande McDonald
  16. #116
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Hopefully. Still have to run all of the fuel lines, primer lines, and one waterline from the head to the pisser. The new pissers are further forward to make it easier to get to and my old lines were too short so I need to find a hose to cannibalize. I also have to figure how I'm going to mount my battery and bilge pump. Then turf, cut the rideplate to fit, and water test. I'm sure everything but the water test could be done after work today if I buckle down. We'll see...
  17. #117
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    Man I've just been plagued with problems this time around... Last week I decided to pressure check the engine just because it was out. That led to me tearing the engine apart because the cylinder had a crack in it. Found out last night when I went to connect the battery that the battery cable isn't long enough........ Uhhhh this cable was the same one I used last year and the electrics, engine, and battery are all in about the same location but I need another 6 inches or so to reach the battery. Not sure how that works. The exhaust tubing I ordered was 2.5" instead of 2.25" like I thought so I was kicking, heating, and fighting to get all the hoses on them.
    Then last night, I was cutting all the turf. Put the sides one without any issues. Measured and very carefully marked and cut the bottom portion of the turf. Put the glue down and when I flipped it over to put it on the ski, I realized that the grooves were going the wrong direction.... The remaining turf was 1.5" too narrow to cut another piece. Guess I'll learn to live with it.
  18. #118
    Join Date
    May 2006
    Cheney lake Kansas
    Posts
    2,039
    Thanks
    70
    Dont you hate it when stuff like that happens. keep your head up ,you got this
  19. #119
    Superfreaks...unite! pabloescobar's Avatar
    Join Date
    Aug 2007
    georgia
    Posts
    2,854
    Thanks
    34
    I turf that way all the time. Floor one direction and the rails another. It look all good to me. I wanna see that mutha run! Get it done. U and Shane r my motivation to put mine back together this week. How'd the cylinder repair go?
    STROKED BUT NOT BORED...
    2010 SuperFreak
    1996 SeaDoo GSX...keeps the chirruns happy
    2000 Toyota Epic 22
  20. #120
    Join Date
    Aug 2007
    Macon, GA
    Posts
    5,739
    Thanks
    29
    I took a magnifying glass trying to find the ends of the crack on the cylinder and then routed it out a little past where I thought it ended (it was on a corner by the front carb). Then filled it with JB Weld, smoothed it out with glass and sand paper, then added copper gasket spray to the gasket to help fill any little imperfections. That didn't work.... So tried one more thing prior to contacting a tig welder who won't touch it for another month or two. I pulled a 10psi vacuum on the engine, mixed some more JB Weld, put that on the area, and then put a heat gun on the epoxy until it had the consistency of thin syrup. By doing this, the epoxy was sucked into the crack which sealed it.
    Don't know how long it'll last but I obviously ran that crack in the cylinder all last year because I was constantly fighting carb issues that I couldn't trace even with a leakdown test. Last year the engine would leak maybe 0.5 psi in 15-20 minutes but I was never able to find the leak. Guess it finally got big enough to find...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
