Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Best 650 prop
  1. #1
    X-H2O.com El Joker's Avatar
    Join Date
    Jul 2011
    La Porte, Indiana
    Posts
    1,164
    Thanks
    259
    Best 650 prop
    What is the best 650 prop? I got a 650 with a westcoast exhaust, dual 38's, a lightened flywheel.
    Ice and aspirin heals any wound 
  2. #2
    X-H2
    Join Date
    May 2011
    lake house
    Posts
    348
    Thanks
    0
    Ive been riding my whole life and i havent found the best PROP yet
    But i do know the best impeller for 650
    U got two options
    If u dnt have enough $$ u can buy a used skat 9/17 or 15.5 for under 110
    But if u have deeo pockets run a c75 9/17 cut to fit 650pump
    Or gwt a stock sxr impeller and repitch to 9/17 and cut to fit 650pump (this setup will run u about 200-250)
    She likes it when i hit it sideways
  3. #3
    Super Hero, with a cape! Vumad's Avatar
    Join Date
    Jun 2007
    St. Pete, FL
    Posts
    4,079
    Thanks
    92
    I've been running a 10/18 with a stock (83mm) nozzle. It seemed to lack bottom end. I put on an AM nozzle (87mm) and gained some bottom end at the cost of a lot of top end. Crab did say 87mm would be too big.
    Crab and Shawn claim the best with a worked 750 motor is a 13/18 with a bored stock (85mm) nozzle.
    Impros suggested I run a 12/17.
    I have a 15, a 15.5 and a 9/17 I have yet to try.
    Group K's website makes some suggestions. They suggest either a 15.5 or a 9/17 with a stock nozzle.
    The Onyx G1
    My 1st Superjet
    Always build with the assistance of a professional from SkiShopRules.com
  4. #4
    Join Date
    Jul 2011
    La Porte, Indiana
    Posts
    1,164
    Thanks
    259
    I want bottom end. I'm going to put on a x2 trim with an 85mm nozzle. I have a guy that has a 16 and 17 skat for 85 which would be best?
  5. #5
    Join Date
    Jun 2007
    St. Pete, FL
    Posts
    4,079
    Thanks
    92
    If he's local, tell him you'll give $95 to try both, but only keep the one that works best for you. Couldn't hurt to ask.
    The Onyx G1
    My 1st Superjet
  6. #6
    Join Date
    Jul 2011
    La Porte, Indiana
    Posts
    1,164
    Thanks
    259
    I could ask but he isn't local I just got ahold of him through email and e sen me his parts list and they were on there. I could ask him and sign a form saying I would return one after I test it.
  7. #7
    X jdakrt's Avatar
    Join Date
    Sep 2006
    Central VA
    Posts
    289
    Thanks
    1
    I ran old skool 15, 15.5, 16 and 13/16 skats on my 650 setup and liked the 13/16 best. as stated above, the 9/17 c75 would be best on the 650. Off topic - save your money and get a 750. night and day difference, I cant believe I waited so long to do the swap. Not just saying that cuz I have a 750 setup fs.
  8. #8
    X-H2O.com kevbo's Avatar
    Join Date
    Sep 2007
    dfw
    Posts
    1,768
    Thanks
    0
    Quote Originally Posted by PowerRanger View Post
    Anything over an old 15, 13-16, or 8-16 will kill low speed thrust. Solas 13-18s are also too much without taking some load out. Its much better to modify a modern 750 prop like an 11-16 concord.
  9. #9
    Join Date
    Jul 2011
    La Porte, Indiana
    Posts
    1,164
    Thanks
    259
    Quote Originally Posted by kevbo View Post
    So i should get a 11-16 concord and get it cut down I fit a 140mm pump?
  10. #10
    Join Date
    Sep 2007
    dfw
    Posts
    1,768
    Thanks
    0
    They are all 140mm diameter, 750s have longer splines and more foreward shaft spacing. A 750xi driveshaft will fit a 650sx and make it so the only mod needed is cutting the bottom to set back the prop. X2s will need both sides cut. The easiest way out is finding a 650 solas ke-sc-I 13-18 and getting it repitched.
  11. #11
    X-H2 smrbum's Avatar
    Join Date
    Sep 2008
    bradford
    Posts
    371
    Thanks
    15
    i have the set up you need for sale .9/17 hooker large hub with R&D pump stuffer,rad dudes spacer all installed in a pump for $500.just bolt in and go
  12. #12
    Lord of the Dance Mr Bojangles's Avatar
    Join Date
    Apr 2010
    Brevard County, Fl
    Posts
    664
    Thanks
    2
    I got a skat 15.5 I will let go cheap, but I run a small hub 13/19 on my 750 and it gets going good, but I need a big hub
    My WCF Build Thread........
    http://www.x-h2o.com/showthread.php?...l-hull-project
    עדיף למלוך בגיהנום מאשר לשרת בגן עדן
  13. #13
    Join Date
    Jul 2011
    La Porte, Indiana
    Posts
    1,164
    Thanks
    259
    Smr I would love to Have that but it would never happen on a high school kids budget
  14. #14
    650sx Snivilous's Avatar
    Join Date
    Jul 2011
    Colorado
    Posts
    702
    Thanks
    68
    I have a SOLAS 14-19 lol
    N2O Injection | -5" Plate | -6" Pole | -7" Hull | Engine Stuff
  15. #15
    X-H2O Austin's Avatar
    Join Date
    May 2011
    Loveland, Colorado
    Posts
    769
    Thanks
    10
    Im running a 15 skat strait edge. It gets my x2 going good in colorado!
    2010 Bob Gen 1 #6
    1996 Yamaha superjet - b-pipe, westcoast head, skat prop
    1990 Kawasaki x2 "ported 768cc" CUSTOM! http://www.x-h2o.com/showthread.php?...inter-x2-build
  16. #16
    Join Date
    Jul 2011
    Colorado
    Posts
    702
    Thanks
    68
    Quote Originally Posted by Austin View Post
    Haha, I think my 14-19 is way too high of pitch for almost any 650 let alone like you said, at our elevation. No idea how it feels compared to others/stock, I sadly put it on at the same time as I put my Factory Pipe (or maybe it was the 44mm carb) on so I can't say how much difference it feels over stock. And it's the recommended for 650sx that Watercraftsuperstore told me lol. Hopefully my winter mods can make full use of it (which I think I need a high pitch prop anyhow for what I'll be doing).
    How does repitching work? Do they shave off part of it? But wouldn't that just change the pitch by a fraction of what it normally would be? Or do they heat it to be malleable and then bend it?
  17. #17
    Join Date
    Jun 2007
    St. Pete, FL
    Posts
    4,079
    Thanks
    92
    Quote Originally Posted by Snivilous View Post
    You could try a larger nozzle diameter. I'll be happy to buy that useless prop from you. $25 shipped. =)
    The Onyx G1
    My 1st Superjet
  18. #18
    Join Date
    Jul 2011
    Colorado
    Posts
    702
    Thanks
    68
    Quote Originally Posted by Vumad View Post
    Woah now, the things like brand new and I paid $200 for it lol.
  19. #19
    Join Date
    Jun 2007
    St. Pete, FL
    Posts
    4,079
    Thanks
    92
    I know. =) I am not interested in it which is why I suggested such a price. Right now I am running a 10/18 with a 87mm AM PJS nozzle. 87mm is too big, but maybe not with a prop like that. I intend to either run my 9/17 with a stock (83mm) nozzle or a 13/18 SXR prop with a bored stock (85mm) nozzle.
    The Onyx G1
    My 1st Superjet
  20. #20
    Join Date
    Jul 2011
    Colorado
    Posts
    702
    Thanks
    68
    Would having "high performance" mods mean that boring the nozzle wouldn't help? I want as much punch as I can get (bottom end) and already have a Factory Pipe, 44 Mikuni, High Comp Head, Lightened flywheel, would boring that help still?
    I feel like 86mm bore would be good for a 14-19.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
