Wdk Rip Rebuild. New to me
Joined
Jul 5, 2012
Likes
120
V-town
#22
Nice long talk with wanderer1, good to hear from someone who has run the 927 and this pipe. He gave me a great starting point for tuning the pipe.
Joined
Jul 5, 2012
Likes
120
V-town
#23
I have pressed the midshaft in as far as I can and am still 3-4mm away from being able to install any bolts into the motor mounts... wondering if I have the wrong midshaft. No markings on it of any kind, will have to measure and see. Is this how all of these builds go? Or just mine?
Joined
Oct 6, 2007
Likes
70
kuna, id
#24
That's the same midshaft that was in the ski when I bought it. What couplers are you using? Can you use a shim on the crank side and one on the shaft side to close the gap?
Sent from my SM-G892U using Tapatalk
JetManiac
Thinking about shredding
Joined
Jun 8, 2008
Likes
3,854
orlando
#25
See if you can loosen motor mounts and slide them back at all. Then you will need to think about egging out the holes in motor mounts some to move back and/or in bedplates to slide back.
Joined
Jul 5, 2012
Likes
120
V-town
#26
I sent that one and one I had to JM to have rebuilt. They were the same number on them. I believe he rebuilt the other one I sent in and gave me a core credit for the other.
I dont have a gap, I just cant get ththe engine back far enough.
Joined
Jul 5, 2012
Likes
120
V-town
#27
I so do not want ro do that to this bed plate.
I tried to move the motor mounts but there isnt much give in them. Crap.
Joined
Oct 6, 2007
Likes
70
kuna, id
#30
Looked back in your previous pics and see what you mean. Are the threads bottoming out in the coupler, or vice versa? Could you machine a little off the end?
I'm pretty sure the shaft that was in mine was from a 1100.
Joined
Jul 5, 2012
Likes
120
V-town
#31
Threads are bottoming out, but the driveshaft is still 1/2" away from end of mid shaft. I may just have to machine that, and then the coupler as well.
Seems pretty normal to me. As a side note I finally got the ss nuts I ordered off ebay for the steering... apparently they came from HongKong, I should read the listing better. Had no idea it would take a month to get 4 nuts.
Joined
Oct 6, 2007
Likes
70
kuna, id
#33
Try the shaft I gave you with the rebuilt carrier.
I used OEM yamaha couplers. The bedplate bolts sat dead center on the motor mount bolt holes.
Joined
Jul 5, 2012
Likes
120
V-town
#34
I traded it to jet manic. I sent both in and he rebuilt one anand gave me credit for the other. They both had the same marking on it. Like 63m . I wish I had it to try!!!!
Quinc
Buy a Superjet
Joined
Feb 19, 2013
Likes
5,660
California
#38
That is pushing the motor further away from the mounts. It needs to come back towards the bulkhead.
I'm ordering another midshaft
Take off the engine side coupler and remove any washers on that one? Also is the coupler threaded as far as it can go onto the engine side?
Joined
Jul 5, 2012
Likes
120
V-town
#40
Figured out the issue with the midshaft.
It was an issue with the couple on the engine.
There was a few messed up threads almost at the bottom. About 3/16" from bottoming out. Cleaned it up with an impact setup on a core crank.
You may notice the red line comingfrom the head to a pisser. Who sells other color water lines?
