Picked this up Friday night. 650 Protec pipe and head. Pulled engine and found pump only rotates 90 before contact. Mid shaft bearing also locked. Engine spins/strong comp-but no gauge verification yet. 2 of the 4 main Pump bolts were wet. It has Protec ride plate, Protec intake grate, and I assume Protec impeller.
I enjoy surf riding and rec riding. Not looking for wild power.
*Goals -repair pump and mid first
-clean up engine bay
-rebuild engine
*Engine goals - mid range power (budget >$1.5k)
I am leaning toward finding 61x cases-and purchasing a JetManiac ported 701 topend kit. New reman crank will be needed. carb rebuild needed (44 Mikuni on the 650 should work with jet change?).
I also plan on reusing the 650 pipe with a 61x exhaust manifold.
-rebuild engine
