- Rentz, GA
And that in a nutshell is why I don't like or recommend wireless cams. They seldom work on the perimeters of service, (where 99% of people want them), and then when you finally break down and run an Ethernet cable out, they don't support POE and now require both 120VAC and Ethernet to function.
Other than falling short a few feet in length, doesn't running a single Cat5e cable out to a 5MP cam seem simpler now? Did you already add a 120VAC outlet or were you using an extension cord to test it out?
I have said it before and will repeat it now. WiFi cams are a bigger hassle to install/setup, are typically of a much lower resolution and almost double the cost of a simple POE cam.
