RN Superjet Colander Build
Joined
May 22, 2017
Likes
608
SW Tenn
#64
I would feather it in with sandpaper first to knock down the high spots then mix up some boat bondo "Cabosil and microspheres" to be able to fare it in and sand to a smooth finish. You dont want to remove the material as much as knock down anything that will cause a nail to hang. Then faring should be easy with the boat bondo.
Actual bondo filler is not good for watercraft you want to make it with thickener and resin.
Joined
Sep 6, 2017
Likes
3
California
#65
Awesome thank you very much for the help.
Joined
Feb 27, 2018
Likes
44
Michigan
#66
I used micro balloons and epoxy resin as my “body filler.” That way there’s no guessing how it’ll bond, and you can vary the thickness of it as you like depending on what ratio you mix the balloons in. Stuff dries hard as a rock, and sands easy. There’s other products out there that achieves the same result of thickening the resin and allowing an easy to sand paste. Just a thought.
But as described above, knock the high spots down with some 80 grit, finish with 120 and fill/flare from there. Good luck dude!
Joined
Feb 27, 2018
Likes
44
Michigan
#68
Yessir! Just don’t go crazy sanding the glass, only knock down high spots and fill from there. I spent $20 on a gallon of micro balloons and that filled my entire bondline, all my repairs, the tunnel work and I still had some leftover. Goes a long way
Joined
Sep 6, 2017
Likes
3
California
#69
Thank you! Huge help. I was losing hope for myself. Might have some more questions down the road.
Joined
Feb 27, 2018
Likes
44
Michigan
#70
Feel free to ask anytime. What worked best for me way to paint a thin coat of resin onto the sanded glass, let it soak and start to gell up, then smear on the resin/micro balloon filler. That way it bonds in well to the resin, and you can mix the filler a little thicker avoiding runs, etc.
Joined
Sep 6, 2017
Likes
3
California
#71
7A70C525-20B5-49B9-AFF6-7FA837E9363F.jpeg Made some progress already. Just need to lay the next side.
Joined
Feb 27, 2018
Likes
44
Michigan
#72
Got the footholds roughed in, will put another 4-5 layers on them so they’re rock solid, and obviously carry that across the tray as well. Shooting for at least 60oz of total biax layup. Goodbye resin lol
