Prop recommendations...
Ct
I put this ski together winter 18/19, but I'm looking for prop recommendations. It's an ET967, pfp, novi 48s, and zeeltronic ignition. Currently has a solas 148 mag pump with a 10/17 cut back prop. Curious if I went with the right pitch or if theres a better pitch. I have another prop here I'd like to send out to get pitched. The ski is tuned and runs excellent but I'm looking for more low end punch. The reduction nozzle is also not bored, I was considering playing with that but again, unsure of where I should go for size. Any input is greatly appreciated.
Sent from my SM-G960U using Tapatalk
What did you end up figuring out? I have the same setup basically with a 150mm Maxx pump, 88mm reduction nozzle, and a 10/15 prop, also what jetting are you running in the Novi? I have a 2.3 needle/seat at 21psi 120 pilot and 125 main
Crab
thanks darin...noswad!
Seattle
Nozzle min 86 and 2mm bigger for turn nozzle, also get a stubby pump cone. My TPE 964 was spinning a 10/17, think I’m at 13/17 now
You should probably list your hull and weight. The hull weight and your weight will definitely play a role in impeller pitch. A lighter, carbon hull will want more pitch than a heavier glass hull. Otherwise you're just guessing and going off someone else recommendation who might have a completely different setup than you.
I have that same setup in a full carbon Polar Composites Vortex. Rips pretty good with a Skat 13/19. Haven't tried anything else. Just finished building/tuning the ski so haven't got much time riding it yet.
Sent from my Pixel 6a using Tapatalk
Hmm I'm considering dropping mine from a 150mm 10/15 skat to a 8/14 this next year, recently went from dual 46mm to dual 48 Novi so spent most my time getting them tuned in right this past few months
