Super Jet Project Dance-floor
Joined
May 22, 2017
Likes
664
SW Tenn
thanks man for the kind words, I really appreciate it.
Got it fared and painted ish. I just got the hull done and there was a mild snafu.
It appears that I didn't put quite enough purple on or it absorbed into the more porous material a little bit faster before I cleared on the nose. I ended up with a bit of a tie-dye appearance. The paint says you can wait 48 hours and reapply so I'm going to grab some more and paint and clear over the affected area . It's not the end of the world.
The plus side is the surface is really smooth so it should be fairly quick work.
Additionally the turf might Clash with this color. I'm going to have to sleep on it but it looks Blue by comparison to the plum. 20190519_231726.jpg 20190519_231541.jpg 20190519_231853.jpg 20190519_231842.jpg 20190519_231902.jpg 20190519_163910.jpg 20190519_231503.jpg 20190519_164006.jpg
Joined
May 22, 2017
Likes
664
SW Tenn
I pulled the Pump shoe out of the old square and a pump. Not sure what this is all about but there is a little red conical peace floating on the drive shaft. I assume it's supposed to go in the front of the impeller but I'm not sure how it's supposed to be retained.
20190521_091010.jpg 20190521_095041.jpg 20190521_111252.jpg 20190521_111230.jpg 20190521_111219_HDR.jpg
kawa js550
I just wanna ride
Joined
Jul 8, 2014
Likes
65
Michigan
View attachment 376599 View attachment 376600 View attachment 376598 View attachment 376596 View attachment 376597
That red piece pushes into the prop like you said. The o rings should be on the other side of the red piece so when you push it in to place its a snug fit.
Joined
May 22, 2017
Likes
664
SW Tenn
Thanks man. I didn't put this pump together myself it came with the ski and this is my first time seeing it. I'm still a noob when it comes to most of the stuff.
yamanube
@TheUnderknown
Staff member
Joined
Jun 22, 2006
Likes
2,840
Those billet nose cones are crap IMO, especially if it doesn't have a set screw. Even with a set screw, I have still had them come loose. I only use the rubber ones now.
Joined
May 22, 2017
Likes
664
SW Tenn
I'm sure I got one off of one of my couch pumps I can steal if they are an oem piece. I got my mid-shaft moved over so I can install the bilge pumps once the paint is finished drying. 20190521_121546_HDR.jpg 20190521_121555_HDR.jpg
Joined
May 22, 2017
Likes
664
SW Tenn
I painted the hood and installed the hood seal. more pictures to come.
P.s. I think the colors will be fine. It looks like the hood is a little bit darker but it hasn't fully cured yet. The hull did the same thing
20190522_154720.jpg 20190522_154636.jpg 20190522_154547.jpg 20190522_154648.jpg 20190522_154643.jpg 20190522_154701.jpg 20190522_154654.jpg
Joined
May 22, 2017
Likes
664
SW Tenn
I glued the bilge pumps in and made some Matt I'm going to glue in for the water box and gas tank. I beveled The Edge a little bit. Good practice for the main Turf job. I installed the drain plugs. I also transferred all the strap hooks into the Hull.
20190522_205315.jpg 20190522_205309.jpg 20190522_205343.jpg 20190522_205333.jpg 20190522_205406.jpg
Joined
May 22, 2017
Likes
664
SW Tenn
I got the pole modified and dropped the engine in. I need to figure out the ebox but I think I can run some studs to the toehold. Got about an inch of clearance between the e-box and the motor if I don't run the brackets.
Running last years motor for now. Going to put my ada head on it however.
20190523_163339_HDR.jpg 20190523_164207_HDR.jpg 20190523_163349.jpg 20190523_165354_HDR.jpg
Joined
May 22, 2017
Likes
664
SW Tenn
The exhaust is completely mocked up. I'm not crazy about the long piece of aluminum tube but the couch hose I had had a bend in it so I made do. I will be coming up with a solution after my trip to Arizona. 20190523_193057.jpg
