Quinc
Buy a Superjet
California
In action!
After riding all of the new hulls with seats over the last few years, MX1, Viper, rockered/chopped blaster, and the Reaper I fell in love with the Reaper. And picked up a new hull at a good price with some paint issues. I haven't been able to find any builds or very much info on building out a new hull so going to document the process here.
Reaper uses all Superjet 2008+ parts
Drive Train:
62t/61x 754cc CPT ported 170psi
TNT b1 exhaust opened to 49mm w/ RN waterbox
38's Ocean pro Carbon flame arrestors Boyesen 2stage reeds
Zeeltronics / WaxCurve
144 Solas Mag / x-metal trim / 10-16 hooker / 08+ driveshaft
Controls:
Yamaha WaveRaider Spring steering
2007 Superjet steering cable
Thrust single finger throttle
Other stuff:
Limited slip 4.8G tank
Silicone long exhaust hose
Rhaas engine mounts
Kenny keeper
R&D intake grate
Dakine foot straps
Parts I still need:
Trim lever
Bars
hood/seat latches
Slowly putting parts on as they show up. And still not sure how I am going to make my steering work. So any tips or suggestions please let me know!
So pretty and light!
Clean up some threads
foot straps installed
Putting what I have in finger tight
Quinc
Buy a Superjet
California
Before receiving the Reaper I had assumed it used the same type of steering setup as the blaster. However it does not. The inside of the blaster hood comes down and allows the bottom of the steering to bolt to the hood. The Reaper hood is open space.
I'm not exactly sure what I am going to do yet, but looks like I will need to make a plate to put under the hood so the bolts have something to bolt too other then just the hood. And then I need to come up with a steering stop.
Brand new yamaha Raider steering still in the package!
Will having a plate on the underside of the hood for this to bolt too be strong enough?
The steering stop that would bolt to the hood.
What it looks like bolted to a blaster. The part circled on blaster is just open space on the Reaper. Hoping another Reaper owner has some tips here other then buy another steering. :)
Quinc
Buy a Superjet
California
A little bracketology. Aluminum or stainless, or fab it up in cardboard and hot glue and do it in CF or S glass. 4 hours tops. Rock it out.
I have some ideas if it comes to that. But it wont be pretty. I have seen some Reapers with UMI steering so people have made it work. Just haven't been able to get any replies or pictures from those people..
Quinc
Buy a Superjet
California
Worx pump shoe install. Dropped right in! lol j/k..
After sanding off all the paint in the shoe area, and sanding the shoe smooth it was pretty close. Then spent about an hour with the air grinder and test fitting. Needs a bit more sanding for it to sit flush. You can see the gap when i did the dry fit.
R&D intake grate needed a ton of grinding to sit flush as well.
Quinc
Buy a Superjet
California
The hull where the water lines are is raised up higher then the rest of the area. Sanded that down and got the shoe to fit flush. Screwed her in and used 4200. Figure if/when I upgrade to a 155 it will be easier to remove then 5200. Bolted and shimmed the pump to hold the shoe while the glue dries and need to grind some more off the R&D.
When you guys fit a pump shoe. Do you try and make if flush with the hull? Then let the grate sit a little higher? Nice build
Quinc
Buy a Superjet
California
This is only second one I have done so I am not an expert. I grind and sand to get the shoe close; then fit with the pump until pump and pump seal are correct. Once I like where the pump is I grind down the top of the shoe to sit flush with the hull. I grind the intake grate as well to get it to sit flush. And did some moderate blueprinting to the grate to help smooth the flow.
Haha I'm far from a pro also. But did the same. Try and make the shoe sit flush. But I have seen a lot of aftermarket hull that don't sit flush so I thought i might messing something up.
Quinc
Buy a Superjet
California
Sure sounds like they need to get a lot better with their molds. It can't be that difficult to get a shoe and adjust the mold from the beginning. All the OEM's seem to be able to do it.
Exactly! However, I don't know how much of it is the shoe Vs the ski without trying an oem shoe first.
