New JM Fuel Shop- Carbs, Carb Parts, Primers, Filters, Intake, Reeds
Flame Arrestor/Air Filters
index.php
Tau Ceti Tornado Series flame arrestor/air filters
Tau Ceti 2" size flame arrestors in black, silver, red, green, or blue.
Tornado Series filters feature a velocity cone with specially designed air channels to increase air flow. The velocity cone is clear/smoke and the outer ring is anodized aluminum. Fit standard carb to f/a adapters.
Tau Ceti/HP 1 1/2" Filter $62.95 sale 55.95
Tau Ceti/HP 2" Filter $63.95 sale 56.95
Tau Ceti/HP 2 1/2" Filter $64.95 sale 57.95
Tau Ceti/HP outerwears 22.85
Prok Flame Arrestors $52.90 sale 47.95/ea.
Prok Prefilters 11.90/ea.
(aka 'raincoats' 'Outerwears')
OEM dual 38 flame arrestor assembly 49.
(clean used, f/a base plate, 2 screens, plastic top with rubber 90 degree, hardware to top and to carbs)
OEM dual 44 flame arrestor assembly 49.
OEM single 44/46 flame arrestor assembly 45.
(oem clean used, base plate, screen, plastic top, hardware to top and to carbs)
JM stainless allen bling bolt kit for OEM sgl f/a 6.
JM stainless allen bling bolt kit for OEM dual f/a 8.
Flame Arrestor to Carb adapters
index.php
ADA billet 44mm carb to flame arrestor adapter 22.99
ADA billet 46mm carb to flame arrestor adapter 22.99
index.php
ADA
SuperJet 38mm carb to flame arrestor adapter 22.99
ADA Kawi SXR carb to flame arrestor adapter 22.99
Billet aluminum air filter adapter for the Mikuni 40mm carb. Fits the stock carb on all Kawasaki SXR800's.
ADA Kawi 1100 carb to flame arrestor adapter 24.99
Flame arrestor adapter for the stock Kawasaki 900('98 and earlier) and 1100ZXi('97 and earlier) carbs. These do NOT fit the newer CV style carbs.
Keihin adapters available also.
Reeds, Intake Manifolds and Carbs
Carbon Tech carbon fiber reed sets
Yamaha 701 61x sgl carb cases -low tension for freestyle $105. sale 95.
Yamaha 701 62t dual carb cases -low tension for freestyle $105. sale 95.
Kawasaki 750/800 carbon reeds 115.
Boyesen Power Reeds -Dual-flex epoxy fiber
Boyesen Power Reeds -Dual-flex epoxy fiber Yamaha 701 61x sgl carb 79.
Boyesen Power Reeds -Dual-flex epoxy fiber Yamaha 701/760 62t dual carb 79.
Kawi 750/800 Boyesen Power Reeds -Dual-flex epoxy fiber 89.
Kawi 650 Boyesen Power Reeds -Dual-flex epoxy fiber 79.
Kawi 550SX Boyesen Power Reeds -Dual-flex epoxy fiber 79.
V-Force 2 Reed Cages and Reeds
The V-Force 2 Reed Valve uses a double row cage design for additional flow at all RPMs. Reed stops and rubber over-molded cages extend reed life and eliminate petal distortion. Specially developed carbon fiber reeds offer the ultimate in response and durability. The V-Force increased flow results in significant horsepower gains with freestyle pulling torque and broader peak horsepower...
Open up and Say 'AHHH!' Let your motor breathe with two rows of reeds instead of one.
VForce 2 mounted on stock/oem intake manifold for dual 38's. Also fit with stock/oem dual 44 manifolds and most a/m manifolds as well.
We have used VF2's in stock 701/bpipe setups and also in ported 701 and Big Bore ported 781's with excellent results for freestyle.
VForce2 Reeds/Cages for Yamaha 62t/64x motors 259. -check with us for any current sale pricing
(2 Cages with carbon reeds, gasket, instructions)
VForce3 Reeds/Cages for Yamaha 62t/64x motors $259. -check for any current sale pricing
(2 Cages with carbon reeds, 4 reed gaskets, instructions)
Replacement Reed Sets
VForce 2
replacement reeds 59.95/cage set
VForce 3 replacement reeds 59.95/cage set
VForce 1 replacement reeds 59.95/cage set
Boyesen replacement RAD valve reed sets 69.95/cage set
Intake Manifolds
index.php
PowerHouse Products (PHP) billet intake manifold $385. sale 319.90
This is a state of the art billet intake manifold for Yamaha 62t or 64x cases. This intake was designed specifically for freestyle and features shorter and better designed intake track for more freestyle low end performance. Removable O-ringed billet carb speed plate makes removing and reinstalling carbs easier while preserving carb linkage alignment.
PowerHouse Products (PHP) billet intake mani $385. sale 319.90
(Includes manifold, speed plate with orings, throttle cable bracket, and all SS hardware)
http://www.x-h2o.com/index.php?threads/php-intake-manifold.162601/
OEM intake manifolds
61x single 44 OEM intake manifold clean, used $18.
62t dual 38 OEM intake manifold clean, used $30.
62t/64x dual 44 OEM intake manifold clean, used $39.90
OEM manifold throttle cable mount brackets
OEM reed cages
61x OEM reed cage with reeds clean, used 19.90
62t OEM reed cage with reeds clean, used 21.95
JM Allen stainless reed cage to manifold bolt kit (4 bolts/washers) 5.
Carburetors
- Mikuni new 44mm SBN racing carb -PM for current pricing
- Mikuni new 46mm SBN racing carb -PM for current pricing
ADA Yamaha or Kawi billet gas caps 64.95
OEM Yamaha clean, used gas cap assembly 29.80
(hull side mount with gasket, chain, and gas cap with gasket, black or white)
Cold Fusion internal fuel fill system 179.90
Blowsion internal fuel fill system $179.
RRP 5 gallon fuel tank kit $389.
- Replaces an oem sized SuperJet tank. Fits all SJ's '90-'20, and all a/m hulls which use SJ tank. 19.5 L/5.15 gal capacity.
- Billet 4 port internal fill with cap allows for all connections with no need to put fittings in tank.
- Natural tank allows for fuel level inspection.
- Comes complete with all necessary hardware and fittings.
(Compare pricing with a new oem tank, then add price of internal fuel fill and a blockoff cap for inlet.)
Lightweight composite tank holder keeps your stock SJ tank from sliding around during riding and is great for surf and big freestyle tricks.
Made by Tigercraft.
SJ OEM or CF fuel tank cradle $98.95
I just registered and do not have the ability to direct message you with an invoice request. Can you direct message me for my parts list?
Thanks,
