Custom/Hybrid Havoc build
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#23
5 -pack of grinding wheels later she’s in.
There’s some gaps on the wings behind the pump shoe bolts. I plan I getting some black permatex silicone and flushing everything up.
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#26
Laying ufo mounts tonite for the limited slip tank and jetmaniac waterbox
I have two different weights of carbon. 5oz and 9oz in case I did tray work.
I’m thinking a couple layers of 5oz with some g flex and cabosile
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#27
@flyinryan had all the mounts set for the pfp and waterbox so I’ll prob use a couple.
Mounted 4 ufo , I added black dye to the gflex and also to the epoxy.
Stuffed the ufo threads with clay prior to install. Once all is cured I’ll use my angle die grinder to sand away down to the threaded nut and run a tap thru to get clay out
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#32
Turf time - last few jobs I did my template in tin foil and they came out well.
Saw someone here use blue painter tape , thought it was a good idea
Easier to get it perfect
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#33
That’s for the 26mm underpad. Not sure but I’ll probably just do 9mm on the underside of the footholds
Joined
Apr 29, 2016
Likes
105
Malvern pa
#34
Looking good! Great pics - always wondered what the hull looked like de-turfed. Im very curious to see what you do with your footholds. I honestly hate mine. Feels like just my toes are locked in and I'm constantly kicking in. Is the right side foot hold a slightly different size/shape than the left? My right foot big toe has taken an absolute beating kicking in but my left foot is fine.
motoman3000
ride
Joined
Aug 14, 2012
Likes
300
new jersey
#35
No idea how I ever did turf without this sander!!
Pretty sure I’m not putting any padding on the tray under the holds. Just 9mm on the underside for tops of my feet, still working it out so plans could change
Roseand
Ready to RIP
Joined
Dec 31, 2012
Likes
2,212
Wisconsin
#37
Definitely put padding underneath your feet if you plan on doing any sort of aerials!
Also, put padding where the front of your ankle meets the foothold.
Sanoman
A.E. Newman
Joined
Jun 23, 2009
Likes
1,994
NE Tenn
#40
“Done with this bull crap , not my finest hour but it will get me on the water”
Havocs aren’t the easiest skis to turf man! You did great!
