DISCONTINUING THE SUPERJET????
Joined
Jul 2, 2017
Likes
26
Hudson River Valley, NY
The housing is a bit below the hull, but has worked out well. The only problem is the sound signature from the russian jet pump is causing problems with my ride. The US Navy keeps surfacing in front of me, with guns out, until they see I'm just a wasted jet skier.....
Joined
Feb 24, 2014
Likes
188
Los Gatos, CA
Why does the pro watercross seem to think a 4-stroke superjet is coming this year? Have they actually confirmed this with yamaha?
They even have rules for it. page 46.
https://prowatercross.org/mt-content/uploads/2020/02/2020_pro_watercross_rule_book-rev_a.pdf
https://prowatercross.org/tour/
Wow, good find!
This section applies to the 4-stroke SuperJet scheduled for release in 2020. The watercraft will be allowed minimal modifications through the duration of the 2020 season to allow time to evaluate performance characteristics of the craft and allow development and manufacturing of parts so that there is equal access to any aftermarket part to all competitors. This watercraft will run in a separate class for the duration of 2020.
Joined
Feb 19, 2013
Likes
5,465
Chico California
27.TECHNICAL RULES –2020 YAMAHA SUPERJET27.1OVERVIEW27.1.1 Description:This section applies to the 4-stroke SuperJet scheduled for release in 2020. The watercraft will be allowed minimalmodifications through the duration of the 2020season to allow time to evaluate performance characteristics of the craft and allow development and manufacturing of parts so that there is equal access to any aftermarket part to all competitors. This watercraft will run in a separate class for the duration of 2020.27.1.2Modifications:These rules catalog the allowable modifications or alterations. If a definition, modification or alteration is not cited, then no modification, alteration or change can be made. 27.1.3General Rules:Watercraft are to remain stock as provided by the manufacture with the exceptions listed below. The following safetyand general rules insection 24of this rulebook apply to this class24.3 –Fuel24.4 –Tow Straps/ Loops / Hooks24.5 –Lanyard/ Tether engine stop switch24.6 –General maintenance and repair27.1.4Hull:padding and/or mat kits may be added and custom painting is allowed. The surface finish of any metal component outside the hull area above the bond flange may be painted, polished or plated.27.1.5Handlebar: Handlebar, grips, throttle, throttle cable may be modified or aftermarket. The handlebar cover may be modified or removed. The handlebar must be padded at the mounting bracket or, if it has a crossbar, the crossbar must be padded
Joined
Aug 20, 2018
Likes
6
Sweden
Wow, good find!
I would love to see a pic or more info on that!
4 stroke superjet!
Hope they keep al the dimension and it will be a bolt on in a blaster ; )
