Broken driveshaft
INDebtSJ
Having a VISION!
Ga
Not sure why things always happen to me but ,dang...
At least I got a few weekends on it before it broke.
JetManiac
Stoked
orlando
oem shafts are built in 3 pieces and right by the threads is one place its put together and they do break there. I've taken the tail cone off and welded a big nut to the back end to hold the shaft and get the prop off.
You were probably just referring to std 90-07 SJ shafts. OEM 90-07 SJ and FX1 tapered shafts and also some couch shafts with the hardened splines are from 3 pieces and have 2 welds, but nontapered 08-up SJ, blaster, and most couch shafts are made from 2 pieces and just have the 1 weld in from of the prop threads..
Beats me. I got the pump /shaft from Dag used.
Might send it all off to jetmaniac for prop removal and new bearings.
That is a nontapered shaft so if in a SJ 90-07 length setup, it is a cut and welded or resplined shaft, but no mods would have been done in the sheared area. I have seen many SJ tapered shafts break there, but do not remember a nontapered one breaking there.
