- Disco bay, ca
Full carbon 2017 XFR
Ordered plain no graphics hull through TC free ride.
Ordered 2 separate graphics kits from RRP Thailand: Trash and classic then combined and applied them myself.
Registered as special construction ski in California, paid and up to date.
Engine started as jet works 950 SS. Sent it to Matt / HPE he made it 4 mil / 999 runs on pump gas.
Most everything else can be seen in pics, cookie cutter reliable build push the green button and ride.
Cold fusion 5 gallon and RRP rear tank makes so it can ride for about 1.5 hours non stop.
My own custom scupper it can float forever without taking on water, also drains water very fast.
Msd enhancer, lightened flywheel, JM water box, 148 pump, thrust trim, medium ride plate, custom scupper primary, versa-plug secondary, couch mounts, ada couplers, 1 spacer, KP pole, jet works steering w bushings, oem spring.
Good ski for someone who wants an AM hull with good power that can be ridden anywhere reliably like an oem ski and pump gas. Flat water flip capable or surf.
RTR weight is 283.
RTR weight is 283.
