2015 Rickter Edge FR Build
IS0LD0UT
I hate winter
Joined
Jan 26, 2010
Likes
153
MN
#21
Back at it today. Dropped in the motor and positioned the motor mounts. Nice and easy.
I Wish I had a shiny new motor for better build pics I didn't even bother cleaning it up.
It fit with the head pipe attached. Very very tight fit though.
dmpus
Joined
May 14, 2011
Likes
188
Boynton Beach
#24
Fit the ebox as far as possible from the bpipe. Mounting bracket bolt will be close to the edge of the firewall. Also consider side wall mounting.
IS0LD0UT
I hate winter
Joined
Jan 26, 2010
Likes
153
MN
#27
Pole is mounted. Very easy assembly.
What are the thoughts on using the midshaft spacers? I would think it would be better to have the engine back however TC says to use them.
IS0LD0UT
I hate winter
Joined
Jan 26, 2010
Likes
153
MN
#30
I didn't use them my engine is back all the way. Using them will put the weight more towards the nose for better high speed cornering.
Thats what I figured. Engine back seems better. And I am a small guy could use more weight.
KMN
Joined
Mar 8, 2014
Likes
190
Minneapolis, Minnesota
#31
Hey Shawn, where did you end up installing your ebox? Any final build pictures?
Also, did your hull come with the midshaft spacer? My XFR did not and I'm not sure if I need it.
